Can I increase the swap size without reinstalling Linux?
safwatonline
EGYPT
SWAP
can i increase the swap size w/o reinstalling Linux , also i heared that i could make a file that acts as swap is this true?
N.B: i am using FC3
regards,
a.safwat
Re: SWAP
Hi, the swap is in a partition so if you resize the partition you can get more swap.
Best Regards
    safwatonline
SWAP
thnx for the reply but the idea is that i dont have SWAP, also this may be a problem if the swap is surrounded by active paritions ?
so let me rephrase how to create new SWAP?
thnx again
Re: SWAP
Hi, ok fisrt you must have space without any partition, if you don`t have you should resize a partition to get free space. After use fdisk or your prefer program to create a partition with type linux swap (82). After that format the new swap partition with the command mkswap /dev/"you swap partition" example: mkswap /dev/hda3. Now you need to edit the file /etc/fstab and add this line:
/dev/"you swap partition" none swap sw 0 0
Best Regards
    safwatonline
Re: SWAP
man for such problems the first thing is to google....so search google for the quickest help....
Re: SWAP
If all you want is to resize the SWAP partition try Partition Magic. It allows to resize most kind of usual partition (try the latest version).
Also you can use a file for SWAP. For that point to the file you in the mkswap command instead of the device refer its MAN page. And modify the /etc/fstab afterwards.
