Mar 17, 2008 #1 Raju_epigon Member level 4 Joined Feb 13, 2008 Messages 77 Helped 5 Reputation 10 Reaction score 0 Trophy points 1,286 Activity points 1,710 sdram routing guidelines Can i get the routing guidelines for Memory section like SDRAM with 133MHZ speeds and DRAMS?
Mar 28, 2008 #2 A antarveena1982 Member level 3 Joined Nov 7, 2007 Messages 65 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,286 Activity points 1,688 memory routing guidelines micron hi Raju For memory section you to make buses to be length matched and in the same routing layer clocks signal must be shielded if any and any differential should go parallel hope this will clear you regards Antarveena
Mar 28, 2008 #3 V venkat_kvr Banned Joined Jan 24, 2007 Messages 207 Helped 32 Reputation 64 Reaction score 16 Trophy points 1,298 Activity points 0 chk this **broken link removed**
Apr 1, 2008 #4 M muralicrl Full Member level 5 Joined Feb 6, 2008 Messages 286 Helped 53 Reputation 106 Reaction score 19 Trophy points 1,298 Location Bangalore Activity points 2,626 Hi, hereby I am attaching a good material on PCB routing guidelines for SDRAM for one of the good products.
