eng.amr2009
Junior Member level 3
BCD Adder
Hi all
I'm Implementing a BCD full adder
my code adds 2 vectors of 16 bits but the problem is that adding 2 BCD8421 digits may produce wrong output for example
9 + 5 = 14 = (0000 1110) where it should be (0001 0100) in correct BCD8421 format
when i examined the truth table i found that i need to extract the carry after each 4 bit addittion to be able to detect the wrong combination in the sum
when i examined the technology schematic i found that the XST uses the carry chain logic to implement the adder where the carry is implemented using the MUXCY
the output of the MUXCY is an internal signal
IS there anyway to extract this internal signal (the output of the MUXCY) ?!!!!!!!!!!!
here is the schematic
thanks in advance
Hi all
thanks in advance
