Can I build a model from data PIN diode datasheet ?
tyassin
Advanced Member level 1
PIN diode model
Hi
I have ti design a switch with PIN diodes. When I look at the datasheets for PIN diodes I can see how the series resistance(Rs) and Cj and other parameters are specified. As far as I can see these are given at one or two frequencies or some curve explaning how the series resistance change with bias. My question is, is it possible to build a model(SPICE or some other kind) from these quantities given in the datasheet.
I have attached the PIN diode datasheet from Microsemi.
Thank you
Re: PIN diode model
Using the data in the datasheet to extract the parameters in the diode model.There is a standard way of doing that.The details are attached.
Reactions: simon_z
    tyassin
    simon_z
Re: PIN diode model
Hi and thanks for the reply.
I also found two application notes from Ansoft that used the same method. But when I try this method and exctract the DC parameters: N, Is and Rs and then put these into a diode SPICE model. I do not get the same result as in the datasheet. So my question is, how precise is this method and should you get a very close result compared to the datasheet.
