Note: This feature currently requires accessing the site using the built-in Safari browser.
You mean you want to be able to use it to generate power ? Like a 'free-energy' source ?
I suppose it conceivably could be, though i have never come across such an application. Possibly because the voltage/ emf is way too small, or some similar limitation.
This should work, if the V+ to V- voltage difference doesn't exceed 10V.I presume,
pin 8 for hall sensor output pin
pin 13 for V+
pin 12 for V-
