Can dimension be added to cells in Expedition design flow?
taring77
Full Member level 2
Expedition problem
Hi all i have a prob...
Expedition Design Flow: Layout Design --
Adding dimensions to cells.
"Dimensions" are not listed as a data base element in the cell editor.
Can dimension be added?
regards
taring
Re: Expedition problem
NO!! On Expedition PCB Layout you can't insert dimension on cell.
In fact, if you go to cell editor --> Draw Mode you'll see that the button "Dimension" will be disable.
mkbs
Expedition problem
how to import orcad netlist in expedition?
You must generate a netlist for Expedition, but at first you have to add a .dll file to your Orcad folders. You can find the name of .dll file and the detailed procedure on Orcad Interface manual.
Or you can use pcb navigator.
Good luck
If we add or delete any nets in expedition pcb is it possible to update(back annotate) them to design capture.
Expedition problem
how i can fix this error?
** Error ** There are no PDB partitions in search scheme 'Variant Manager'
Lmc Parser operation complete...
i checked for the PDB partition, it have one entries.
still it give an error
Binu G
