Can anyone help me to solve a problem related to boot loader programming of ATmega256
chirag2239
Member level 3
Member level 3
Hi All,
I am making a device which operates the relay by WiFi. My problem is that I need that programming as a boot loader programming. So can anyone tell me what is boot loader programming? How it can be done? How complex is it to program?
I have a confusion that I have purchased an Arduino Board of ATmega2560 for this project. So can I use this program for a simple or other ATmega2560? I am asking this question because I am a beginner in Programming. I am working on Arduino and ATmega2560 and WiFi for the first time.
If anyone have a ready code for interfacing CC3000 Wifi chip with ATmega2560, then please send me over my mail ID : chirag2239@gmail.com
I know this is available on Adafruit arduino site but I am unable to download it. If someone can post that program, then it will be enough.
Thanks.
Chirag
@file Adafruit_CC3000.cpp
@author KTOWN (Kevin Townsend for Adafruit Industries)
@license BSD (see license.txt)
This is a library for the Adafruit CC3000 WiFi breakout board
This library works with the Adafruit CC3000 breakout
----> https://www.adafruit.com/products/1469
Check out the links above for our tutorials and wiring diagrams
These chips use SPI to communicate.
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
@section HISTORY
v1.0 - Initial release
#include "Adafruit_CC3000.h"
#include "ccspi.h"
#include "utility/cc3000_common.h"
#include "utility/evnt_handler.h"
#include "utility/hci.h"
#include "utility/netapp.h"
#include "utility/nvmem.h"
#include "utility/security.h"
#include "utility/socket.h"
#include "utility/wlan.h"
#include "utility/debug.h"
#include "utility/sntp.h"
uint8_t g_csPin, g_irqPin, g_vbatPin, g_IRQnum, g_SPIspeed;
static const uint8_t dreqinttable[] = {
#if defined(__AVR_ATmega168__) || defined(__AVR_ATmega328P__) || defined (__AVR_ATmega328__) || defined(__AVR_ATmega8__)
2, 0,
3, 1,
#elif defined(__AVR_ATmega1281__) || defined(__AVR_ATmega2561__) || defined(__AVR_ATmega2560__) || defined(__AVR_ATmega1280__)
2, 0,
3, 1,
21, 2,
20, 3,
19, 4,
18, 5,
#elif defined(__AVR_ATmega32U4__) && defined(CORE_TEENSY)
5, 0,
6, 1,
7, 2,
8, 3,
#elif defined(__AVR_AT90USB1286__) && defined(CORE_TEENSY)
0, 0,
1, 1,
2, 2,
3, 3,
36, 4,
37, 5,
18, 6,
19, 7,
#elif defined(__arm__) && defined(CORE_TEENSY)
0, 0, 1, 1, 2, 2, 3, 3, 4, 4,
5, 5, 6, 6, 7, 7, 8, 8, 9, 9,
10, 10, 11, 11, 12, 12, 13, 13, 14, 14,
15, 15, 16, 16, 17, 17, 18, 18, 19, 19,
20, 20, 21, 21, 22, 22, 23, 23, 24, 24,
25, 25, 26, 26, 27, 27, 28, 28, 29, 29,
30, 30, 31, 31, 32, 32, 33, 33,
7, 4,
3, 0,
2, 1,
0, 2,
1, 3,
#elif defined(__arm__) && defined(__SAM3X8E__) // Arduino Due
30, 30, 31, 31, 32, 32, 33, 33, 34, 34,
35, 35, 36, 36, 37, 37, 38, 38, 39, 39,
40, 40, 41, 41, 42, 42, 43, 43, 44, 44,
45, 45, 46, 46, 47, 47, 48, 48, 49, 49,
50, 50, 51, 51, 52, 52, 53, 53, 54, 54,
55, 55, 56, 56, 57, 57, 58, 58, 59, 59,
60, 60, 61, 61, 62, 62, 63, 63, 64, 64,
65, 65, 66, 66, 67, 67, 68, 68, 69, 69,
70, 70, 71, 71,
#endif
uint8_t pingReportnum;
netapp_pingreport_args_t pingReport;
#define CC3000_SUCCESS (0)
#define CHECK_SUCCESS(func,Notify,errorCode) {if ((func) != CC3000_SUCCESS) { CHECK_PRINTER CC3KPrinter->println(F(Notify)); return errorCode;}}
#define MAXSSID (32)
#define MAXLENGTHKEY (32) /* Cleared for 32 bytes by TI engineering 29/08/13 */
#define MAX_SOCKETS 32 // can change this
boolean closed_sockets[MAX_SOCKETS] = {false, false, false, false};
/* PRIVATE FIELDS (SmartConfig) */
class CC3000BitSet {
public:
static const byte IsSmartConfigFinished = 0x01;
static const byte IsConnected = 0x02;
static const byte HasDHCP = 0x04;
static const byte OkToShutDown = 0x08;
void clear() {
flags = 0;
bool test(const byte flag) {
return (flags & flag) != 0;
void set(const byte flag) {
flags |= flag;
void reset(const byte flag) {
flags &= ~flag;
private:
volatile byte flags;
}cc3000Bitset;
volatile long ulSocket;
char _cc3000_prefix[] = { 'T', 'T', 'T' };
Print* CC3KPrinter; // user specified output stream for general messages and debug
/* PRIVATE FUNCTIONS */
@brief Scans for SSID/APs in the CC3000's range
@note This command isn't available when the CC3000 is configured
in 'CC3000_TINY_DRIVER' mode
@returns False if an error occured!
#ifndef CC3000_TINY_DRIVER
bool Adafruit_CC3000::scanSSIDs(uint32_t time)
const unsigned long intervalTime[16] = { 2000, 2000, 2000, 2000, 2000,
2000, 2000, 2000, 2000, 2000, 2000, 2000, 2000, 2000, 2000, 2000 };
if (!_initialised)
return false;
// We can abort a scan with a time of 0
if (time)
CHECK_PRINTER {
CC3KPrinter->println(F("Started AP/SSID scan\n\r"));
// Set SSID Scan params to includes channels above 11
CHECK_SUCCESS(
wlan_ioctl_set_scan_params(time, 20, 100, 5, 0x1FFF, -120, 0, 300,
(unsigned long * ) &intervalTime),
"Failed setting params for SSID scan", false);
return true;
#endif
/* CONSTRUCTORS */
@brief Instantiates a new CC3000 class.
Note that by default this class will assume the first hardware
serial should be used for debug output. This behavior can be
changed by explicitly specifying a cc3kPrinter parameter.
Adafruit_CC3000::Adafruit_CC3000(uint8_t csPin, uint8_t irqPin, uint8_t vbatPin, uint8_t SPIspeed, Print* cc3kPrinter)
_initialised = false;
g_csPin = csPin;
g_irqPin = irqPin;
g_vbatPin = vbatPin;
g_IRQnum = 0xFF;
g_SPIspeed = SPIspeed;
cc3000Bitset.clear();
CC3KPrinter = cc3kPrinter;
/* PUBLIC FUNCTIONS */
@brief Setups the HW
@args[in] patchReq
Set this to true if we are starting a firmware patch,
otherwise false for normal operation
@args[in] useSmartConfig
Set this to true if you want to use the connection details
that were stored on the device from the SmartConfig process,
otherwise false to erase existing profiles and start a
clean connection
bool Adafruit_CC3000::begin(uint8_t patchReq, bool useSmartConfigData, const char *_deviceName)
if (_initialised) return true;
#if defined(digitalPinToInterrupt)
// digitalPinToInterrupt macro is supported on Arduino 1.0.6+ and 1.5.6+
// returns NOT_AN_INTERRUPT (-1 = 0xFF) if g_irqPin is not mapped to an INT
#ifndef NOT_AN_INTERRUPT
#define NOT_AN_INTERRUPT (-1)
#endif
g_IRQnum = digitalPinToInterrupt(g_irqPin);
#elif !defined(CORE_ADAX)
// determine irq #
for (uint8_t i=0; i<sizeof(dreqinttable); i+=2) {
if (g_irqPin == dreqinttable[i]) {
g_IRQnum = dreqinttable[i+1];
if (g_IRQnum == 0xFF) {
CHECK_PRINTER {
CC3KPrinter->println(F("IRQ pin is not an INT pin!"));
return false;
#else
g_IRQnum = g_irqPin;
// (almost) every single pin on Xmega supports interrupt
#endif
init_spi();
DEBUGPRINT_F("init\n\r");
wlan_init(CC3000_UsynchCallback,
sendWLFWPatch, sendDriverPatch, sendBootLoaderPatch,
ReadWlanInterruptPin,
WlanInterruptEnable,
WlanInterruptDisable,
WriteWlanPin);
DEBUGPRINT_F("start\n\r");
wlan_start(patchReq);
DEBUGPRINT_F("ioctl\n\r");
// Check if we should erase previous stored connection details
// (most likely written with data from the SmartConfig app)
if (!useSmartConfigData)
// Manual connection only (no auto, profiles, etc.)
wlan_ioctl_set_connection_policy(0, 0, 0);
// Delete previous profiles from memory
wlan_ioctl_del_profile(255);
else
// Auto Connect - the C3000 device tries to connect to any AP it detects during scanning:
// wlan_ioctl_set_connection_policy(1, 0, 0)
// Fast Connect - the CC3000 device tries to reconnect to the last AP connected to:
// wlan_ioctl_set_connection_policy(0, 1, 0)
// Use Profiles - the CC3000 device tries to connect to an AP from profiles:
wlan_ioctl_set_connection_policy(0, 0, 1);
CHECK_SUCCESS(
wlan_set_event_mask(HCI_EVNT_WLAN_UNSOL_INIT |
//HCI_EVNT_WLAN_ASYNC_PING_REPORT |// we want ping reports
//HCI_EVNT_BSD_TCP_CLOSE_WAIT |
//HCI_EVNT_WLAN_TX_COMPLETE |
HCI_EVNT_WLAN_KEEPALIVE),
"WLAN Set Event Mask FAIL", false);
_initialised = true;
// Wait for re-connection if we're using SmartConfig data
if (useSmartConfigData)
// Wait for a connection
uint32_t timeout = 0;
while(!cc3000Bitset.test(CC3000BitSet::IsConnected))
cc3k_int_poll();
if(timeout > WLAN_CONNECT_TIMEOUT)
CHECK_PRINTER {
CC3KPrinter->println(F("Timed out using SmartConfig data"));
return false;
timeout += 10;
delay(10);
delay(1000);
if (cc3000Bitset.test(CC3000BitSet::HasDHCP))
mdnsAdvertiser(1, (char *) _deviceName, strlen(_deviceName));
return true;
@brief Prints a hexadecimal value in plain characters
@param data Pointer to the byte data
@param numBytes Data length in bytes
void Adafruit_CC3000::printHex(const byte * data, const uint32_t numBytes)
if (CC3KPrinter == 0) return;
uint32_t szPos;
for (szPos=0; szPos < numBytes; szPos++)
CC3KPrinter->print(F("0x"));
// Append leading 0 for small values
if (data[szPos] <= 0xF)
CC3KPrinter->print(F("0"));
CC3KPrinter->print(data[szPos], HEX);
if ((numBytes > 1) && (szPos != numBytes - 1))
CC3KPrinter->print(' ');
CC3KPrinter->println();
@brief Prints a hexadecimal value in plain characters, along with
the char equivalents in the following format
00 00 00 00 00 00 ......
void Adafruit_CC3000::printHexChar(const byte * data, const uint32_t numBytes)
uint32_t szPos;
CC3KPrinter->print('0');
CC3KPrinter->print(" ");
if (data[szPos] <= 0x1F)
CC3KPrinter->print('.');
else
CC3KPrinter->print(data[szPos]);
@brief Helper function to display an IP address with dots
void Adafruit_CC3000::printIPdots(uint32_t ip) {
CC3KPrinter->print((uint8_t)(ip));
CC3KPrinter->print((uint8_t)(ip >> 8));
CC3KPrinter->print((uint8_t)(ip >> 16));
CC3KPrinter->print((uint8_t)(ip >> 24));
@brief Helper function to display an IP address with dots, printing
the bytes in reverse order
void Adafruit_CC3000::printIPdotsRev(uint32_t ip) {
@brief Helper function to convert four bytes to a U32 IP value
uint32_t Adafruit_CC3000::IP2U32(uint8_t a, uint8_t b, uint8_t c, uint8_t d) {
uint32_t ip = a;
ip <<= 8;
ip |= b;
ip <<= 8;
ip |= c;
ip <<= 8;
ip |= d;
return ip;
@brief Reboot CC3000 (stop then start)
void Adafruit_CC3000::reboot(uint8_t patch)
if (!_initialised)
return;
wlan_stop();
delay(5000);
wlan_start(patch);
@brief Stop CC3000
void Adafruit_CC3000::stop(void)
if (!_initialised)
return;
wlan_stop();
@brief Disconnects from the network
bool Adafruit_CC3000::disconnect(void)
if (!_initialised)
return false;
long retVal = wlan_disconnect();
return retVal != 0 ? false : true;
@brief Deletes all profiles stored in the CC3000
bool Adafruit_CC3000::deleteProfiles(void)
if (!_initialised)
return false;
CHECK_SUCCESS(wlan_ioctl_set_connection_policy(0, 0, 0),
"deleteProfiles connection failure", false);
CHECK_SUCCESS(wlan_ioctl_del_profile(255),
"Failed deleting profiles", false);
return true;
@brief Reads the MAC address
@param address Buffer to hold the 6 byte Mac Address
bool Adafruit_CC3000::getMacAddress(uint8_t address[6])
if (!_initialised)
return false;
CHECK_SUCCESS(nvmem_read(NVMEM_MAC_FILEID, 6, 0, address),
"Failed reading MAC address!", false);
return true;
@brief Sets a new MAC address
@param address Buffer pointing to the 6 byte Mac Address
bool Adafruit_CC3000::setMacAddress(uint8_t address[6])
if (!_initialised)
return false;
if (address[0] == 0)
return false;
CHECK_SUCCESS(netapp_config_mac_adrress(address),
"Failed setting MAC address!", false);
wlan_stop();
delay(200);
wlan_start(0);
return true;
@brief Set the CC3000 to use a static IP address when it's connected
to the network. Use the cc3000.IP2U32 function to specify the
IP, subnet mask (typically 255.255.255.0), default gateway
(typically 192.168.1.1), and DNS server (can use Google's DNS
of 8.8.8.8 or 8.8.4.4). Note that the static IP configuration
will be saved in the CC3000's non-volatile storage and reused
on next reconnect. This means you only need to call this once
and the CC3000 will remember the setting forever. To revert
back to use DHCP, call the cc3000.setDHCP function.
@param ip IP address
@param subnetmask Subnet mask
@param defaultGateway Default gateway
@param dnsServer DNS server
@returns False if an error occurred, true if successfully set.
bool Adafruit_CC3000::setStaticIPAddress(uint32_t ip, uint32_t subnetMask, uint32_t defaultGateway, uint32_t dnsServer)
// Reverse order of bytes in parameters so IP2U32 packed values can be used with the netapp_dhcp function.
ip = (ip >> 24) | ((ip >> 8) & 0x0000FF00L) | ((ip << 8) & 0x00FF0000L) | (ip << 24);
subnetMask = (subnetMask >> 24) | ((subnetMask >> 8) & 0x0000FF00L) | ((subnetMask << 8) & 0x00FF0000L) | (subnetMask << 24);
defaultGateway = (defaultGateway >> 24) | ((defaultGateway >> 8) & 0x0000FF00L) | ((defaultGateway << 8) & 0x00FF0000L) | (defaultGateway << 24);
dnsServer = (dnsServer >> 24) | ((dnsServer >> 8) & 0x0000FF00L) | ((dnsServer << 8) & 0x00FF0000L) | (dnsServer << 24);
// Update DHCP state with specified values.
if (netapp_dhcp(&ip, &subnetMask, &defaultGateway, &dnsServer) != 0) {
return false;
// Reset CC3000 to use modified setting.
wlan_stop();
delay(200);
wlan_start(0);
return true;
@brief Set the CC3000 to use request an IP and network configuration
using DHCP. Note that this DHCP state will be saved in the
CC3000's non-volatile storage and reused on next reconnect.
This means you only need to call this once and the CC3000 will
remember the setting forever. To switch to use a static IP,
call the cc3000.setStaticIPAddress function.
bool Adafruit_CC3000::setDHCP()
return setStaticIPAddress(0,0,0,0);
@brief Reads the current IP address
bool Adafruit_CC3000::getIPAddress(uint32_t *retip, uint32_t *netmask, uint32_t *gateway, uint32_t *dhcpserv, uint32_t *dnsserv)
if (!_initialised) return false;
if (!cc3000Bitset.test(CC3000BitSet::IsConnected)) return false;
if (!cc3000Bitset.test(CC3000BitSet::HasDHCP)) return false;
tNetappIpconfigRetArgs ipconfig;
netapp_ipconfig(&ipconfig);
/* If byte 1 is 0 we don't have a valid address */
if (ipconfig.aucIP[3] == 0) return false;
memcpy(retip, ipconfig.aucIP, 4);
memcpy(netmask, ipconfig.aucSubnetMask, 4);
memcpy(gateway, ipconfig.aucDefaultGateway, 4);
memcpy(dhcpserv, ipconfig.aucDHCPServer, 4);
memcpy(dnsserv, ipconfig.aucDNSServer, 4);
return true;
@brief Gets the two byte ID for the firmware patch version
bool Adafruit_CC3000::getFirmwareVersion(uint8_t *major, uint8_t *minor)
uint8_t fwpReturn[2];
if (!_initialised)
return false;
CHECK_SUCCESS(nvmem_read_sp_version(fwpReturn),
"Unable to read the firmware version", false);
*major = fwpReturn[0];
*minor = fwpReturn[1];
return true;
#endif
@Brief Prints out the current status flag of the CC3000
status_t Adafruit_CC3000::getStatus()
if (!_initialised)
return STATUS_DISCONNECTED;
long results = wlan_ioctl_statusget();
switch(results)
case 1:
return STATUS_SCANNING;
break;
case 2:
return STATUS_CONNECTING;
break;
case 3:
return STATUS_CONNECTED;
break;
case 0:
default:
break;
#endif
@brief Calls listSSIDs and then displays the results of the SSID scan
For the moment we only list these via CC3KPrinter->print since
this can consume a lot of memory passing all the data
back with a buffer
ResultStruct_t SSIDScanResultBuff;
bool Adafruit_CC3000::startSSIDscan(uint32_t *index) {
if (!_initialised)
return false;
// Setup a 4 second SSID scan
if (!scanSSIDs(4000))
// Oops ... SSID scan failed
return false;
// Wait for results
delay(4500);
CHECK_SUCCESS(wlan_ioctl_get_scan_results(0, (uint8_t* ) &SSIDScanResultBuff),
"SSID scan failed!", false);
*index = SSIDScanResultBuff.num_networks;
return true;
void Adafruit_CC3000::stopSSIDscan(void) {
// Stop scanning
scanSSIDs(0);
uint8_t Adafruit_CC3000::getNextSSID(uint8_t *rssi, uint8_t *secMode, char *ssidname) {
uint8_t valid = (SSIDScanResultBuff.rssiByte & (~0xFE));
*rssi = (SSIDScanResultBuff.rssiByte >> 1);
*secMode = (SSIDScanResultBuff.Sec_ssidLen & (~0xFC));
uint8_t ssidLen = (SSIDScanResultBuff.Sec_ssidLen >> 2);
strncpy(ssidname, (char *)SSIDScanResultBuff.ssid_name, ssidLen);
ssidname[ssidLen] = 0;
"Problem with the SSID scan results", false);
return valid;
#endif
@brief Starts the smart config connection process
bool Adafruit_CC3000::startSmartConfig(const char *_deviceName, const char *smartConfigKey, uint32_t timeout)
bool enableAES = smartConfigKey != NULL;
uint32_t time = 0;
if (!_initialised) {
return false;
// Reset all the previous configurations
CHECK_SUCCESS(wlan_ioctl_set_connection_policy(WIFI_DISABLE, WIFI_DISABLE, WIFI_DISABLE),
"Failed setting the connection policy", false);
// Delete existing profile data
"Failed deleting existing profiles", false);
// CC3KPrinter->println("Disconnecting");
// Wait until CC3000 is disconnected
while (cc3000Bitset.test(CC3000BitSet::IsConnected)) {
cc3k_int_poll();
CHECK_SUCCESS(wlan_disconnect(),
"Failed to disconnect from AP", false);
delay(10);
hci_unsolicited_event_handler();
// Reset the CC3000
wlan_stop();
delay(1000);
wlan_start(0);
// create new entry for AES encryption key
CHECK_SUCCESS(nvmem_create_entry(NVMEM_AES128_KEY_FILEID,16),
"Failed create NVMEM entry", false);
if (enableAES)
// write AES key to NVMEM
CHECK_SUCCESS(aes_write_key((unsigned char *)(smartConfigKey)),
"Failed writing AES key", false);
//CC3KPrinter->println("Set prefix");
CHECK_SUCCESS(wlan_smart_config_set_prefix((char *)&_cc3000_prefix),
"Failed setting the SmartConfig prefix", false);
//CC3KPrinter->println("Start config");
// Start the SmartConfig start process
CHECK_SUCCESS(wlan_smart_config_start(enableAES),
"Failed starting smart config", false);
// Wait for smart config process complete (event in CC3000_UsynchCallback)
while (!cc3000Bitset.test(CC3000BitSet::IsSmartConfigFinished))
cc3k_int_poll();
// waiting here for event SIMPLE_CONFIG_DONE
time+=10;
if (time > timeout) // default of 60s
return false;
delay(10); // ms
// CC3KPrinter->print('.');
CHECK_PRINTER {
CC3KPrinter->println(F("Got smart config data"));
if (enableAES) {
CHECK_SUCCESS(wlan_smart_config_process(),
"wlan_smart_config_process failed",
false);
// Decrypt configuration information and add profile
// ToDo: This is causing stack overflow ... investigate
// CHECK_SUCCESS(wlan_smart_config_process(),
// "Smart config failed", false);
// Connect automatically to the AP specified in smart config settings
CHECK_SUCCESS(wlan_ioctl_set_connection_policy(WIFI_DISABLE, WIFI_DISABLE, WIFI_ENABLE),
"Failed setting connection policy", false);
// Reset the CC3000
wlan_stop();
delay(1000);
wlan_start(0);
// Mask out all non-required events
CHECK_SUCCESS(wlan_set_event_mask(HCI_EVNT_WLAN_KEEPALIVE |
"Failed setting event mask", false);
time = 0;
cc3k_int_poll();
if (time > WLAN_CONNECT_TIMEOUT) // default of 10s
CHECK_PRINTER {
CC3KPrinter->println(F("Timed out waiting to connect"));
return false;
time += 10;
delay(10);
delay(1000);
return true;
#endif
Connect to an unsecured SSID/AP(security)
@param ssid The named of the AP to connect to (max 32 chars)
bool Adafruit_CC3000::connectOpen(const char *ssid)
return false;
"Failed to set connection policy", false);
delay(500);
CHECK_SUCCESS(wlan_connect(WLAN_SEC_UNSEC,
(const char*)ssid, strlen(ssid),
0 ,NULL,0),
"SSID connection failed", false);
#else
wlan_connect(ssid, strlen(ssid));
#endif
return true;
//! CC3000_UsynchCallback
//! @param lEventType Event type
//! @param data
//! @param length
//! @return none
//! @brief The function handles asynchronous events that come from CC3000
//! device and operates a led for indicate
void CC3000_UsynchCallback(long lEventType, char * data, unsigned char length)
if (lEventType == HCI_EVNT_WLAN_ASYNC_SIMPLE_CONFIG_DONE)
cc3000Bitset.set(CC3000BitSet::IsSmartConfigFinished);
if (lEventType == HCI_EVNT_WLAN_UNSOL_CONNECT)
cc3000Bitset.set(CC3000BitSet::IsConnected);
if (lEventType == HCI_EVNT_WLAN_UNSOL_DISCONNECT)
cc3000Bitset.reset(CC3000BitSet::IsConnected | CC3000BitSet::HasDHCP);
if (lEventType == HCI_EVNT_WLAN_UNSOL_DHCP)
cc3000Bitset.set(CC3000BitSet::HasDHCP);
if (lEventType == HCI_EVENT_CC3000_CAN_SHUT_DOWN)
cc3000Bitset.set(CC3000BitSet::OkToShutDown);
if (lEventType == HCI_EVNT_WLAN_ASYNC_PING_REPORT)
//PRINT_F("CC3000: Ping report\n\r");
pingReportnum++;
memcpy(&pingReport, data, length);
if (lEventType == HCI_EVNT_BSD_TCP_CLOSE_WAIT) {
uint8_t socketnum;
socketnum = data[0];
//PRINT_F("TCP Close wait #"); printDec(socketnum);
if (socketnum < MAX_SOCKETS)
closed_sockets[socketnum] = true;
Connect to an SSID/AP(security)
bool Adafruit_CC3000::connectSecure(const char *ssid, const char *key, int32_t secMode)
return false;
if ( (secMode < 0) || (secMode > 3)) {
CHECK_PRINTER {
CC3KPrinter->println(F("Security mode must be between 0 and 3"));
return false;
if (strlen(ssid) > MAXSSID) {
CHECK_PRINTER {
CC3KPrinter->print(F("SSID length must be < "));
CC3KPrinter->println(MAXSSID);
return false;
if (strlen(key) > MAXLENGTHKEY) {
CHECK_PRINTER {
CC3KPrinter->print(F("Key length must be < "));
CC3KPrinter->println(MAXLENGTHKEY);
return false;
false);
delay(500);
CHECK_SUCCESS(wlan_connect(secMode, (char *)ssid, strlen(ssid),
NULL,
(unsigned char *)key, strlen(key)),
/* Wait for 'HCI_EVNT_WLAN_UNSOL_CONNECT' in CC3000_UsynchCallback */
return true;
#endif
// Connect with timeout
bool Adafruit_CC3000::connectToAP(const char *ssid, const char *key, uint8_t secmode, uint8_t attempts) {
return false;
int16_t timer;
// If attempts is zero interpret that as no limit on number of retries.
bool retryForever = attempts == 0;
do {
// Stop if the max number of attempts have been tried.
if (!retryForever) {
if (attempts == 0) {
return checkConnected();
attempts -= 1;
cc3k_int_poll();
/* MEME: not sure why this is absolutely required but the cc3k freaks
if you dont. maybe bootup delay? */
scanSSIDs(4000);
// Wait for results
delay(4500);
scanSSIDs(0);
/* Attempt to connect to an access point */
CHECK_PRINTER {
CC3KPrinter->print(F("\n\rConnecting to "));
CC3KPrinter->print(ssid);
CC3KPrinter->print(F("..."));
if ((secmode == 0) || (strlen(key) == 0)) {
/* Connect to an unsecured network */
if (! connectOpen(ssid)) {
CHECK_PRINTER {
CC3KPrinter->println(F("Failed!"));
continue;
} else {
/* NOTE: Secure connections are not available in 'Tiny' mode! */
/* Connect to a secure network using WPA2, etc */
if (! connectSecure(ssid, key, secmode)) {
CHECK_PRINTER {
continue;
#endif
timer = WLAN_CONNECT_TIMEOUT;
/* Wait around a bit for the async connected signal to arrive or timeout */
CHECK_PRINTER {
CC3KPrinter->print(F("Waiting to connect..."));
while ((timer > 0) && !checkConnected())
cc3k_int_poll();
delay(10);
timer -= 10;
if (timer <= 0) {
CHECK_PRINTER {
CC3KPrinter->println(F("Timed out!"));
} while (!checkConnected());
return true;
uint16_t Adafruit_CC3000::ping(uint32_t ip, uint8_t attempts, uint16_t timeout, uint8_t size) {
if (!_initialised) return 0;
if (!cc3000Bitset.test(CC3000BitSet::IsConnected)) return 0;
if (!cc3000Bitset.test(CC3000BitSet::HasDHCP)) return 0;
uint32_t revIP = (ip >> 24) | ((ip >> 8) & 0xFF00) | ((ip & 0xFF00) << 8) | (ip << 24);
pingReportnum = 0;
pingReport.packets_received = 0;
//if (CC3KPrinter != 0) {
// CC3KPrinter->print(F("Pinging ")); printIPdots(revIP); CC3KPrinter->print(" ");
// CC3KPrinter->print(attempts); CC3KPrinter->println(F(" times"));
netapp_ping_send(&revIP, attempts, size, timeout);
delay(timeout*attempts*2);
//if (CC3KPrinter != 0) CC3KPrinter->println(F("Req report"));
//netapp_ping_report();
//if (CC3KPrinter != 0) { CC3KPrinter->print(F("Reports: ")); CC3KPrinter->println(pingReportnum); }
if (pingReportnum) {
CC3KPrinter->print(F("Sent: ")); CC3KPrinter->println(pingReport.packets_sent);
CC3KPrinter->print(F("Recv: ")); CC3KPrinter->println(pingReport.packets_received);
CC3KPrinter->print(F("MinT: ")); CC3KPrinter->println(pingReport.min_round_time);
CC3KPrinter->print(F("MaxT: ")); CC3KPrinter->println(pingReport.max_round_time);
CC3KPrinter->print(F("AvgT: ")); CC3KPrinter->println(pingReport.avg_round_time);
return pingReport.packets_received;
} else {
return 0;
#endif
uint16_t Adafruit_CC3000::getHostByName(char *hostname, uint32_t *ip) {
int16_t r = gethostbyname(hostname, strlen(hostname), ip);
//if (CC3KPrinter != 0) { CC3KPrinter->print("Errno: "); CC3KPrinter->println(r); }
return r;
#endif
Checks if the device is connected or not
@returns True if connected
bool Adafruit_CC3000::checkConnected(void)
return cc3000Bitset.test(CC3000BitSet::IsConnected);
Checks if the DHCP process is complete or not
@returns True if DHCP process is complete (IP address assigned)
bool Adafruit_CC3000::checkDHCP(void)
// Ugly hack to fix UDP issues with the 1.13 firmware by calling
// gethostbyname on localhost. The output is completely ignored
// but for some reason this call is necessary or else UDP won't
// work. See this thread from TI for more details and the genesis
// of the workaround: http://e2e.ti.com/support/wireless_connectivity/f/851/t/342177.aspx
// Putting this in checkDHCP is a nice way to make it just work
// for people without any need to add to their sketch.
if (cc3000Bitset.test(CC3000BitSet::HasDHCP)) {
uint32_t output;
gethostbyname("localhost", 9, &output);
return cc3000Bitset.test(CC3000BitSet::HasDHCP);
Checks if the smart config process is finished or not
@returns True if smart config is finished
bool Adafruit_CC3000::checkSmartConfigFinished(void)
return cc3000Bitset.test(CC3000BitSet::IsSmartConfigFinished);
Gets the IP config settings (if connected)
bool Adafruit_CC3000::getIPConfig(tNetappIpconfigRetArgs *ipConfig)
netapp_ipconfig(ipConfig);
return true;
#endif
@brief Quick socket test to pull contents from the web
Adafruit_CC3000_Client Adafruit_CC3000::connectTCP(uint32_t destIP, uint16_t destPort)
sockaddr socketAddress;
int32_t tcp_socket;
// Create the socket(s)
//if (CC3KPrinter != 0) CC3KPrinter->print(F("Creating socket ... "));
tcp_socket = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);
if (-1 == tcp_socket)
CHECK_PRINTER {
CC3KPrinter->println(F("Failed to open socket"));
return Adafruit_CC3000_Client();
//CC3KPrinter->print(F("DONE (socket ")); CC3KPrinter->print(tcp_socket); CC3KPrinter->println(F(")"));
closed_sockets[tcp_socket] = false; // Clear any previous closed event
// Try to open the socket
memset(&socketAddress, 0x00, sizeof(socketAddress));
socketAddress.sa_family = AF_INET;
socketAddress.sa_data[0] = (destPort & 0xFF00) >> 8; // Set the Port Number
socketAddress.sa_data[1] = (destPort & 0x00FF);
socketAddress.sa_data[2] = destIP >> 24;
socketAddress.sa_data[3] = destIP >> 16;
socketAddress.sa_data[4] = destIP >> 8;
socketAddress.sa_data[5] = destIP;
CHECK_PRINTER {
CC3KPrinter->print(F("\n\rConnect to "));
printIPdotsRev(destIP);
CC3KPrinter->print(':');
CC3KPrinter->println(destPort);
//printHex((byte *)&socketAddress, sizeof(socketAddress));
//if (CC3KPrinter != 0) CC3KPrinter->print(F("Connecting socket ... "));
if (-1 == ::connect(tcp_socket, &socketAddress, sizeof(socketAddress)))
CHECK_PRINTER {
CC3KPrinter->println(F("Connection error"));
closesocket(tcp_socket);
//if (CC3KPrinter != 0) CC3KPrinter->println(F("DONE"));
return Adafruit_CC3000_Client(tcp_socket);
Adafruit_CC3000_Client Adafruit_CC3000::connectUDP(uint32_t destIP, uint16_t destPort)
int32_t udp_socket;
// socket = SOCK_STREAM, SOCK_DGRAM, or SOCK_RAW
// protocol = IPPROTO_TCP, IPPROTO_UDP or IPPROTO_RAW
//if (CC3KPrinter != 0) CC3KPrinter->print(F("Creating socket... "));
udp_socket = socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP);
if (-1 == udp_socket)
CHECK_PRINTER {
//if (CC3KPrinter != 0) { CC3KPrinter->print(F("DONE (socket ")); CC3KPrinter->print(udp_socket); CC3KPrinter->println(F(")")); }
CHECK_PRINTER {
CC3KPrinter->print(F("Connect to "));
if (-1 == ::connect(udp_socket, &socketAddress, sizeof(socketAddress)))
CHECK_PRINTER {
closesocket(udp_socket);
return Adafruit_CC3000_Client(udp_socket);
Adafruit_CC3000_Client::Adafruit_CC3000_Client(void) {
_socket = -1;
Adafruit_CC3000_Client::Adafruit_CC3000_Client(uint16_t s) {
_socket = s;
bufsiz = 0;
_rx_buf_idx = 0;
Adafruit_CC3000_Client::Adafruit_CC3000_Client(const Adafruit_CC3000_Client& copy) {
// Copy all the members to construct this client.
_socket = copy._socket;
bufsiz = copy.bufsiz;
_rx_buf_idx = copy._rx_buf_idx;
memcpy(_rx_buf, copy._rx_buf, RXBUFFERSIZE);
void Adafruit_CC3000_Client::operator=(const Adafruit_CC3000_Client& other) {
// Copy all the members to assign a new value to this client.
_socket = other._socket;
bufsiz = other.bufsiz;
_rx_buf_idx = other._rx_buf_idx;
memcpy(_rx_buf, other._rx_buf, RXBUFFERSIZE);
Adafruit_CC3000_Client::operator bool()
return connected();
int Adafruit_CC3000_Client::connect(const char *host, uint16_t port){
// if (!_initialised) return 0;
// if (!ulCC3000Connected) return 0;
// if (!ulCC3000DHCP) return 0;
uint32_t ip = 0;
int16_t r = gethostbyname(host, strlen(host), &ip);
if (ip!=0 && r!=0)
return connect(ip, port);
else
return 0;
int Adafruit_CC3000_Client::connect(IPAddress destIP, uint16_t destPort)
bufsiz = 0;
_rx_buf_idx = 0;
int32_t tcp_socket;
CHECK_PRINTER {
return 0;
CHECK_PRINTER {
CC3KPrinter->print(destIP);
CHECK_PRINTER {
return 0;
// if (CC3KPrinter != 0) CC3KPrinter->println(F("DONE"));
_socket = tcp_socket;
return 1;
uint8_t Adafruit_CC3000_Client::connected(void) {
if (_socket < 0) return false;
if (! available() && closed_sockets[_socket] == true) {
//if (CC3KPrinter != 0) CC3KPrinter->println("No more data, and closed!");
closesocket(_socket);
closed_sockets[_socket] = false;
_socket = -1;
return false;
else return true;
size_t Adafruit_CC3000_Client::write(const void *buf, uint16_t len, uint32_t flags)
return send(_socket, buf, len, flags);
size_t Adafruit_CC3000_Client::write(const uint8_t *buf, size_t len)
return write(buf, len, 0);
size_t Adafruit_CC3000_Client::write(uint8_t c)
int32_t r;
r = send(_socket, &c, 1, 0);
if ( r < 0 ) return 0;
return r;
size_t Adafruit_CC3000_Client::fastrprint(const __FlashStringHelper *ifsh)
char _tx_buf[TXBUFFERSIZE];
uint8_t idx = 0;
const char PROGMEM *p = (const char PROGMEM *)ifsh;
size_t n = 0;
while (1) {
unsigned char c = pgm_read_byte(p++);
if (c == 0) break;
_tx_buf[idx] = c;
idx++;
if (idx >= TXBUFFERSIZE) {
// lets send it!
n += send(_socket, _tx_buf, TXBUFFERSIZE, 0);
idx = 0;
if (idx > 0) {
// Send any remaining data in the transmit buffer.
n += send(_socket, _tx_buf, idx, 0);
return n;
size_t Adafruit_CC3000_Client::fastrprintln(const __FlashStringHelper *ifsh)
size_t r = 0;
r = fastrprint(ifsh);
r+= fastrprint(F("\r\n"));
return r;
size_t Adafruit_CC3000_Client::fastrprintln(const char *str)
size_t r = 0;
size_t len = strlen(str);
if (len > 0) {
if ((r = write(str, len, 0)) <= 0) return 0;
if ((r += write("\r\n", 2, 0)) <= 0) return 0; // meme fix
return r;
size_t Adafruit_CC3000_Client::fastrprint(const char *str)
if (len > 0) {
return write(str, len, 0);
else {
return 0;
size_t Adafruit_CC3000_Client::fastrprint(char *str)
if (len > 0) {
else {
return 0;
size_t Adafruit_CC3000_Client::fastrprintln(char *str) {
size_t r = 0;
r = fastrprint(str);
return r;
int Adafruit_CC3000_Client::read(void *buf, uint16_t len, uint32_t flags)
return recv(_socket, buf, len, flags);
int Adafruit_CC3000_Client::read(uint8_t *buf, size_t len)
return read(buf, len, 0);
int32_t Adafruit_CC3000_Client::close(void) {
int32_t x = closesocket(_socket);
_socket = -1;
return x;
void Adafruit_CC3000_Client::stop(){
close();
int Adafruit_CC3000_Client::read(void)
while ((bufsiz <= 0) || (bufsiz == _rx_buf_idx)) {
cc3k_int_poll();
// buffer in some more data
bufsiz = recv(_socket, _rx_buf, sizeof(_rx_buf), 0);
if (bufsiz == -57) {
close();
return 0;
//if (CC3KPrinter != 0) { CC3KPrinter->println("Read "); CC3KPrinter->print(bufsiz); CC3KPrinter->println(" bytes"); }
_rx_buf_idx = 0;
uint8_t ret = _rx_buf[_rx_buf_idx];
_rx_buf_idx++;
//if (CC3KPrinter != 0) { CC3KPrinter->print("("); CC3KPrinter->write(ret); CC3KPrinter->print(")"); }
return ret;
int Adafruit_CC3000_Client::available(void) {
// not open!
if (_socket < 0) return 0;
if ((bufsiz > 0) // we have some data in the internal buffer
&& (_rx_buf_idx < bufsiz)) { // we havent already spit it all out
return (bufsiz - _rx_buf_idx);
// do a select() call on this socket
timeval timeout;
fd_set fd_read;
memset(&fd_read, 0, sizeof(fd_read));
FD_SET(_socket, &fd_read);
timeout.tv_sec = 0;
timeout.tv_usec = 5000; // 5 millisec
int16_t s = select(_socket+1, &fd_read, NULL, NULL, &timeout);
//if (CC3KPrinter != 0) } CC3KPrinter->print(F("Select: ")); CC3KPrinter->println(s); }
if (s == 1) return 1; // some data is available to read
else return 0; // no data is available
void Adafruit_CC3000_Client::flush(){
// No flush implementation, unclear if necessary.
int Adafruit_CC3000_Client::peek(){
cc3k_int_poll();
close();
return 0;
_rx_buf_idx = 0;
return ret;
void Adafruit_CC3000::setPrinter(Print* p) {
CC3KPrinter = p;
I ignore whether the response above solved your problems, but if not you should post your question on the microprocessor forum, and there will be far more knowledgeable people than in the power forum
Can you please share the whole zip file here in which application, library of CC3000 and other files are included? Please share here I can not download it from Github. actually after waiting a lot, that page does not opens. if you can share the whole folder here, then I will be much thankful to you.
Thanks.
Chirag
ok fine check the attachment
  • Adafruit_CC3000_Library-master.zip
