alarasi
Junior Member level 1
hello guys
i want to feed an analog bipolar signal (that has negative and positve values) into ADC of a PIC whic only receives positive values!
so i had an amplifier which bias the output signal into half of the supply voltage which means that if the supply voltage is 5v then the reference voltage will be 2.5v (instead of 0v) so that i can feed the signal into the ADC to acept the bipolar signal!
i'm using a mic to detect sound then preamplifiy it, my problem is that when i detect sound the reference voltage (let's assume 2.5v) varies with the sound detected -,+ 0.1-0.9 added to the reference voltage while when i remove the mic it becomes stable!
my question is , does the ADC reading get affceted if the reference voltage or offset voltage varies and unstable ?? or it stll can read and convert the voltage?
thank you
thank you
