can you tell me which type of counter to use?
what is the function called when you save the value to a 10-bit register?
For data transmission we use POV.
Klaus
ah.. so i need external 50MHz oscillator to get clock frequency to give me the 20ns resolution i want (no clock divider)
Create a design that does everything you require (ignoring clock frequency input used) including the sample rate required to meet the performance requirements for resolution and accuracy. Keep iterating on the design until you have something that will meet all your requirements. Then pick the component used based on what your design requires, instead of picking a component and then trying to force your design to fit. Only with extensive experience comes the ability to pick a component that should work for an application, even then there is more risk with it being the wrong choice.So, having this as a fact, the next step before starting ( would say, mandatory ) is you sketch a diagram of what you want to do, so that can use this like a checklist to verify if your code is doing everything as expected.
