januar1983
- Joined
- Dec 11, 2005
- Messages
- 40
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Afghanistan
- Activity points
- 1,478
Re: Can 89S programmed using USBasp?
hi pranam, this firmware working good to program 89S51&52 but when program 89S8253 it's say "can't enter programming mode", have you tested yet?
I want make it USBasp can program 89S8253, cause at now I work with 89S8253 and my laptop didn't have parallel port, so I confuse how to program the chip.
I have make the program using proteus and want see a program in real hardware.
Thanks in advance
The original firmware what is available from USB asp is not capable of programming 89Sxx. next came a new modified firmware whcih is a direct replacement to the later and when used with ProgISP was possible to program the 89Sxx series. What you use is the same what was found as a new firmware and it should work well. many have sucessfully done this which can be found on this thread with ample discussions.
Cheers
Thanks in advance
