calculator program bt using micro controller
suga
chennai
Hi
calculator program by using micro controller.In that I need some ideas.I wrote upto press a keys in keypad means number will display on lcd.futher I have to write a coding for calculator plz help for that.
I assume you want a basic calculator. That means * , / , - , +
Those are basic operations that do not need any fancy algorithms and can be implemented as such. Simply store the user input (numbers as well as operations) and do the calculations and display the result.
This should be simple enough. Try it out and post more questions IF you get stuck somewhere.
how to store the user input?? and this is pgm
#include<reg51.h>
#define p0 P0
#define p2 P2
unsigned int i,m0,m1,v1;
sbit c1=P2^4;
sbit c2=P2^5;
sbit c3=P2^6;
sbit c4=P2^7;
sbit r1=P2^0;
sbit r2=P2^1;
sbit r3=P2^2;
sbit r4=P2^3;
sfr a=0x90;
sbit rs=P3^7;
sbit rw=P3^6;
sbit en=P3^5;
void lcd();
void keypad();
int add(int m1,int m2);
void lcd_d( char val);
void lcd_in( char val);
void wait(int j)
long int i;
for(i=0;i<j;i++);
void main()
int m1,m2;
p2=0x0f;
lcd();
while(1)
keypad();
void keypad()
if( c3=0,c2=c1=c4=1,r1==0)
p0=0x20;
lcd_d('/');
if (c4=0,c2=c3=c1=1,r1==0)
p0=0x30;
lcd_d('*');
if(c1=0,c2=c3=c4=1,r2==0)
p0=0x40;
lcd_d('-');
if( c2=0,c1=c3=c4=1,r2==0)
p0=0x50;
lcd_d('+');
if( c3=0,c2=c1=c4=1,r2==0)
p0=0x60;
lcd_d('9');
if (c4=0,c2=c3=c1=1,r2==0)
p0=0x70;
lcd_d('8');
if(c1=0,c2=c3=c4=1,r3==0)
p0=0x80;
lcd_d('7');
if( c2=0,c1=c3=c4=1,r3==0)
p0=0x90;
lcd_d('6');
if( c3=0,c2=c1=c4=1,r3==0)
p0=0xa0;
lcd_d('5');
if (c4=0,c2=c3=c1=1,r3==0)
p0=0xb0;
lcd_d('4');
if(c1=0,c2=c3=c4=1,r4==0)
p0=0xc0;
lcd_d('3');
if( c2=0,c1=c3=c4=1,r4==0)
p0=0xd0;
lcd_d('2');
v1=v1+2;
if( c3=0,c2=c1=c4=1,r4==0)
p0=0xe0;
lcd_d('1');
if (c4=0,c2=c3=c1=1,r4==0)
p0=0xf0;
lcd_d('0');
man,have you ever used a uC ? just pick up a dev kit and give it a shot ! Things might sound scary if you're a noob and I put them down into text
But if you follow a simple tutorial on your dev kit,you'll realise that it's so very easy.
And since you asked :-
< badly formatted pseudocode >
int a = {user input number 1}
int b = {user input number 2}
float c=0 ;
if(multiply)
{ c= a*b; }
if(divide)
{ c=a/b; }
.......< and so on > .....
.....finally....
function_display(c);
I have to display on LCD.here am using 4x4 keypad.
i have to display on 16x2 LCD with 4x4 keypad but by using MCU 8051 ide software...i don't have any idea how to do it..can someone help
