Calculation of analytical power for analog and mixed-signal design
ashvani88
Hello All,
Can anyone tell the methods to for calculation of analytical power for analog and mixed signal circuits? I didn't find any method for the calculation of analytical power calulation for analog and mixed signal IC (basic concept regarding it without using simulation tool) for a rough idea before i simulate the circuit. Thanks in advance. I am eagerly waiting for your suggestions.
For the digital part, add the power per clock (µW/MHz) values of the std. cells and multiply with the clock rate.
For the analog part, add the current consumptions per cell and multiply with the power supply voltage.
Should be good enough for a raw estimation.
Thank you so much. What about for mixed signal IC. If I have to take a rough idea just by pencil and paper without using simulation tool.
That was my answer for. A mixed signal IC consists of a digital and an analog part. If you know how much of both parts contribute, you can estimate its power consumption.
