Calculating Maximum Gain
Mr.Simplicity
Newbie level 2
For a square-wave with 100 microseconds period requiring total harmonic distortion of less than or equal to 10%, what will be the maximum gain?
Please do not just give the final answer. I want to understand the question and the steps involved in carrying out such a calculation?
Thank you
crutschow
Advanced Member level 5
Colorado USA Zulu -7
What do you mean that the harmonic distortion must be less than 10%? A square-wave has much more than 10% distortion.
And what does that have to do with gain? :???:
LvW
Germany
Thank you
So you want to understand your question? We too!
Mr.Simplicity
Newbie level 2
I am taking a sensors and instrumentation course this term at school. This question was from a series of three questions. I will post all the questions below so that you have a better understanding, though I do not think they are interrelated. I am quiet confused and did not mean to confuse more people. I understand and know how to solve the first two questions but the third question just blew my mind.
1. For a sine wave with 14V(pk) amplitude, what is the large signal bandwidth?
2. for a triangular wave with 14V(pk) amplitude, what is the large signal bandwidth?
3. For a square-wave with 100 microseconds period requiring total harmonic distortion of less than or equal to 10%, what will be the maximum gain?
Thanks
crutschow
I can understand your confusion. The third question makes no sense to me as stated. It requires more information before an answer can be supplied. I don't understand what 10% harmonic distortion has to do with amplifying a square-wave, and I don't understand what gain has to do with anything, since no signal levels are stated.
Junus2012
Italy
Hello
the harmonic distortion is a large signal behavioural of the operational amplifier. when the signal exceeding the maximum allowable slew rate it will experience the non linear distortion
among all of the three signal the easiest one is the square wave. the maximum limit with no harmonic distortion is
maximum output frequency = pulse amplitude / 2.(S.R+linear settling time) or maximum output pulse = frequency.(S.R+linear settling time)
the frequency is 1/signal time
but I believe that even through this condition the output signal still will have a certain harmonic distortion because the signal is going under the large signal condition where the amplifier is not fully linear
but me too I am interest to know how to solve this mathematically for a certain percent
Thanks
LvW
Germany
Thanks
I supose, you forgot the main part of the questions: All signals are applied to an opamp - and the questions are related to the OUTPUT signal. Is this correct?
Only in this case, the questions make sense. However, in order to answer the questions we need to know the opamp parameters. Otherwise the first two questions cannot be answered.
Junus2012
Italy
yes, it seem to be like an output of an operational amplifier
LvW
Germany
Don`t you have a clear description of the task?
Questions cannot be answered without knowing opamp parameters.
Junus2012
Italy
it is not me, Mr.Simplicity who posted that :)
FvM
Super Moderator
Staff member
Bochum, Germany
That should be assumed. Nevertheless THD of a square wave is a completely meaningless specification, I think. Or do you have an idea how to define it?
I'm not aware of a commonly used THD definition applicable to square waves.
LvW
Germany
Perhaps 10% rise time - referred to the period - of the output square wave? Perhaps Mr.Simplicity can provide us with some additional information?
