Jan 27, 2012 #1 W_Heisenberg Full Member level 4 Joined Feb 27, 2011 Messages 217 Helped 6 Reputation 12 Reaction score 6 Trophy points 1,298 Location Boston Activity points 2,575 Hi, all I am doing a layout with cadence now. I got DRC checking and saw this: warning: substrate/well soft connected add power/ground label if neccesary Any genius tells me what does this mean? BTW, adding label is to add label from LSW? Like the very last third option? Thanks in advance.
Jan 27, 2012 #2 Somashekhar Member level 2 Joined Jan 4, 2010 Messages 47 Helped 9 Reputation 18 Reaction score 8 Trophy points 1,288 Location India Activity points 1,538 W_Heisenberg , Whenever two nets are connected using MOAT or POLY it is called as SOFT Connection. In ur case connect the well with the metal, that warning ll be cleared.
Jan 27, 2012 #3 W_Heisenberg Full Member level 4 Joined Feb 27, 2011 Messages 217 Helped 6 Reputation 12 Reaction score 6 Trophy points 1,298 Location Boston Activity points 2,575 Man, I finally figure this out The way I fixed it is here: Creat -> Pins ... -> shape pin -> (meanwhile giving name in the blank) -> (then drag the pin in the layout window) -> done! Thanks for your help though. Sincerly
Mar 15, 2013 #4 S soheyl468 Newbie level 1 Joined Mar 15, 2013 Messages 1 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,285 Hi, I draw a layout with cadence. In DRC checking, I saw this message: warning: substrate/well soft connected add power/ground label if necessary I did all thing, but I couldn't do it. I used pin (Metal1_T) and drag the name of power in my vdd, however it doesn't work. Please help me. Thank you.
Mar 15, 2013 #5 erikl Super Moderator Staff member Joined Sep 9, 2008 Messages 8,108 Helped 2,695 Reputation 5,370 Reaction score 2,307 Trophy points 1,393 Location Germany Activity points 44,123 Use a contact between nwell and metal1 and directly route it to vdd .
