Cadence source parametric Analysis 6
streamc
Junior Member level 2
I have a schematic with two VDC.
I want to variate their voltage from 0 to 5V and see the output.
I launch ADE, go to variables/edit. Add variable alta with value 0V, altb with same value.
Then I go to Tools/parametric Analysis.
What I need to do?
In cadence 6,the place from where you run simulation there is list of variables which says inclusion list.Just specify any name in Vdc souce in schemetic, the specify name automaticly come as varible.When variable shown the place i said
,Just doble click on inclusion list option and you will see window where you can easily specify range.
in ADE go to Tools -> parametric analysis and set variables to change from to and run the simulations
