Cadence IC610 "base" type release
NIALA
Junior Member level 1
Minneapolis
Hi everyone !!!
I am facing a wall in my attempt to install cadence IC610 on a Lenovo T61 with Centos 6-2 on linux distribution.
I took 6 sequential screenshot to details all the steps confer attachments.
phase 1: (1) I extract 35 rar files and i obtained a iso file name Cadence_IC610.iso.
(2) I extract the iso file Cadence_IC610.iso and i got a folder name Cadence_IC610
phase2: The folder Cadence_IC610 contain 2 folder and a file .
(1) IC610_lnx86.base
(2) IC610_lnx86.ISR200612081658
(3) ic610_*1.dat;1
In phase2 I dont know which folder should I used and why do we need a file name ic610_*1.dat;1
phase3: The IC610_lnx86.base contain five folder name CDROM1 ..... TO CDROM 5
phase4: The IC610_lnx86.ISR200612081658 contain three folder name CDROM1 ..... TO CDROM 3
phase5: I open the folder CDROM 1 of IC610_lnx86.base amoung different files and folder with a weird extension ;1 i found the SETUP.SH file but in my case its SETUP.SH;1
phase 6: I open a terminal and become root. I mount to CDROM1 of IC610_lnx86.base , like you can see with the ls command. I try to run the setup file with different command: ./SETUP.SH or ./SETUP.SH;1 without any luck.
"no such file or directory", it seems like the SETUP.SH file isnt an executable file .
I cant launch installscape . If anyone have an idea it will be greatly appreciated.....
thanks for your help!!!!!!
There are several dependencies files that you need to install
libelf1
ksh
nscd
policykit
ureadahead
csh
libc6-i386 lib32gcc1 lib32z1 lib32stdc++6 ia32-libs
Reactions: NIALA
    NIALA
... I try to run the setup file with different command: ./SETUP.SH or ./SETUP.SH;1 without any luck.
"no such file or directory", it seems like the SETUP.SH file isnt an executable file.
Just an idea, don't know if this helps:
Linux probably needs the full file name, but doesn't like the semicolon of the ";1" version control extension. You must "literalize" the semicolon with a backslash. Try:
ls -l ./SETUP.SH\;1 # to see if it's executable
./SETUP.SH\;1 # to execute it
Reactions: NIALA
    NIALA
Re: Cadence IC610 "base" type release
Thanks Erikl , I tried your command :
I installed libelf1 and ksh but the others seemed to be already install or generate an error when i tried to include them on centos 6-2
So you have to make it executable first:
chmod 755 ./SETUP.SH\;1
