cadence ic 5141 on redhat 9 or enterprise 4 AS
asueee
cadence ic
I have successfully installed cadence ic 5141 (3cd of base and 3 cd of isr) on redhat 9, but do not know what to do next, i do not know how to set enviroment and set license, even though there is tons of discussion here, I still ge stuck. Could anybody provide detail instructions on how to setup after installation on Redhat 9 or Redhat Enterprise 4 AS? ( I am just a beginner of Linux, I know how to install and also know the very basic stuff, but not very famalir with the linux command) thanks! by the way, the path where I install is : /usr/cadence/
easy4880
Newbie level 5
Newbie level 5
cadence ic
see these 2 posts
asueee
cadence ic5141 download
I did read these two before, but do they apply to 5141 on AS 3 or 4, what is your experience? Thanks.
Jerry Yau
Member level 4
Member level 4
cadence ic 5141
I didn't run IC5141 in RH9 and RHEL4. But I run IC5141 on RH7.3 and RHEL3. icds,icfb and dracula run well on RH7.3.
icds and icfb run well on RHEL3 but dracula get core dump on RHEL3.
asueee
could not set up softload
Ok, I just installed it on Redhat AS 3, then could you give me detail instruction on how to configure so as to get it run? Thanks.
Added after 22 minutes:
by the way, I need ICFB only.
Jerry Yau
Member level 4
Member level 4
red hat cadence
Add following lines into your .bashrc
export CDS_ROOT=/ap/EDA/IC5141/
export CDS_INST_DIR=$CDS_ROOT
#export CDS_Netlisting_Mode=Analog
export CLS_CDSD_COMPATIBILITY_LOCKING=NO
export CDSDIR=$CDS_ROOT/tools
export XKEYSYMDB=$CDS_ROOT/share/cdssetup/tdmX11/XKeysymDB
export XNLSPATH=$CDS_ROOT/share/cdssetup/tdmX11/nls
#export LD_LIBRARY_PATH=$CDS_ROOT/tools.lnx86/lib:$LD_LIBRARY_PATH
PATH=$PATH:$CDSDIR/bin
PATH=$PATH:$CDSDIR/dfII/bin
PATH=$PATH:$CDSDIR/SKILL06.00/context
PATH=$PATH:$CDSDIR/SKILL06.10/context
PATH=$PATH:$CDSDIR/dracula/bin
LM_LICENSE_FILE=/ap/EDA/license/cadence.dat
asueee0
Full Member level 1
download cadence ic
i copy the code you provide in .bashrc and when I type icfb&, there is still nothing come out, could you provide more detailed and specific instruction? the directory where I installed cadence is /usr/cadence, thanks.
Memphis
Member level 3
Member level 3
how to install cadence ic5141
I have run ic5141 at centos v4.x, this version is equal to the enterprise version of RedHat, and there is no problem at all. As far as I know, there is no need to set LD_LIBRARY_PATH since it will be set automatically when you running the script of launching icfb. Besides, you should add the command "export LD_ASSUME_KERNEL=2.4.1" in your bashrc to prevent some error message. Hope this is helpful for you..:D
asueee0
Full Member level 1
ic5141 redhat 9
when you installed 5141, what kind of technology library and process model (such as tsmc 2.5) it comes with and where could i find them after installation? thanks.
Jerry Yau
Member level 4
Member level 4
ld_assume_kernel cadence
For : asueee0
You have to change some variables according to you environemnt. EG :
export CDS_ROOT=/usr/cadence
and do following in /usr/cadence
ln -s tools.lnx86 tools
Added after 2 minutes:
For Memphis :
Can you succesfully execute DRACULA tools? For example: run jxrun.com that generated by PDRACULA.
Thanks.
Jerry Yau
asueee0
Full Member level 1
what is cadence ic5141
Thanks Mr yao, after modified the path, i got it run at last;
Thanks Memphis, after adding the code you provided, the error message disappear;
Additional question:
It seems that there is no technoogy library in my installation, where can i find them?
Jerry Yau
Member level 4
Member level 4
install cadence ic 5 on red hat enterprise
Check with your foundry.
asueee0
Full Member level 1
installing cadence, softload
when I refered to some online tuitorials (for example:https://www.cadence.ncsu.edu/NCSUCadenceTutorial/NCSUhspiceTutorial.pdf page 4)
on cadence, the screen usually displayed follwing librarys:
NCSU_Analog_Parts
NCSU_Digital_Parts
NCSU_basic
NCSU_Sheet_8ths
how could I obatined or where to download these librarys and how to install them?
thanks.
fugi
Newbie level 3
Newbie level 3
installing cadence from disk
I've tried installing Cadence ic5141 in Fedora 4 (as root) using
LD_ASSUME_KERNEL=2.4.1 ./SETUP.SH
but I continue getting the below error.
Setting up softload for lnx86 in /home/Giorgos/Cadence
The following tar errors were detected:
/bin/tar: -b1: Not found in archive
/bin/tar: Error exit delayed from previous errors
Could not set up SoftLoad in /home/Giorgos/Cadence
You must have write permissions to install directory
and all its subdirectories
and atleast 10 MB available disk
space in install directory.
asueee0
Full Member level 1
redhat 9 ic5141
I want to very your ic5141 CD content before you could install:
How many files are there in the subfolder "IMAGES.DIR" in your ic5141 base CD1?
How many files are there in the subfolder "IMAGES.DIR" in your usr CD1?
karl6833
cadence ic5141 could not set up softload
try tar 1.13 version
you can find it in RH9
Angler25
system requirements for cadence ic5141
I tried installing IC5141 on RH AS4 and at the beginning I got the following message:
Starting up SoftLoad in GUI mode \c
DISPLAY environment variable is set to :0.0\c
If you do not see the SoftLoad console \c
window or the SoftLoad ASCII menu and\c
./SETUP.SH seems to be hanging then kill this \c
process.\c
Set your DISPLAY environment variable to a proper\c
value and manually start SoftLoad
Can anyone give me detailed information on how to set this display variable, please?
Maybe it is because I don't have the color depth set to 8 or 24 bits, but again I dunno how to do this.
The only thing I can set in my display options is the resolution and other things, but I don't see the color depth selection.
I appreciate any kind of help.
ee171
Member level 5
Member level 5
redhat display variable enterprise
it is on the same website.just download the pdk
xhunter
using cadence ic
I couldn't overcome the NCSU Hit-Kit working problem with IC5141.
I reload IC5033. Can someone inform me how to set up the Kit on IC5141 on Sun Solaris 10.
ray_82
Newbie level 3
Newbie level 3
cadence ic5141 install
I am looking for a newer version of Cadence (newer than IC5.0.33) Could you help me?
