Mika_
Newbie level 1
Hello there,
My P&R script works fine when I run it for the first time after starting Cadence Encounter 8.1. If I run it more than once, I get OffMGrid DRC errors. Thus, I need to restart Encounter every time I want to run the script. I have the 'freeDesign' command in the beginning of the script, so Encounter should clear all information about the previous runs from the memory, but the problem remains.
Has anyone encountered this problem and found another solution?
