C6713 Device Cycle Accurate Simulator
bachehkaraji
Newbie level 2
I'm a beginner on DSP.
I have started to study the book "Digital Signal Processing and Applications with the C6713 and C6416 DSK (by Rulph Chassaing, 2005)".
I am working with a C6713DSK, using CCS 3.1.
But when I try to run the first example (sine8_LED) in Rulph Chassaing's book on the C6713 Device Cycle Accurate Simulator, I get the following error messages:
Trouble running Target CPU: Memory Map Error: READ access by CPU to address 0x1b7c100, which is RESERVED in Hardware.
Trouble running Target CPU: Memory Map Error: WRITE access by Default to address 0x1b7c100, which is RESERVED in Hardware.
Please tell me what the wrong is here and how can be solved.
Please ,Please ,Please help me!
Thanks a lot
