C source code for the implementation of IEC1107 on the MCU
Vicent Yang
Member level 5
Member level 5
Taiwan
I need a C source code for the implementation of IEC1107 on the MCU.
Vicent
iec 1107
hi,
i have been looking for this protocol for quite sometime and i can't even get any.
do you have this protocol document?
i think there is a modbus c code in this forum that you can use to modify to iec1107.
kindly email me if you have any info on this protocol.
thanks.
wisely
iec1107 protocol
Hi
There was an artical on Ele*ktor magazine published on march 2002
RS232<->IEC1107
Get this artical maybe you can learn more
All the best
Bobi
iec-1107
I cannot access the article.
is there any other project or protocol or command info?
Aji
1107 protocol
IEC 1107 is a protocol to read meters. The protocol defines the basic shell.
To communicate with a particular meter will require more specific data about a given manufaturers meter and possibly a password. Some European meters use OBIS codes so are standard.
iec1107
About the protocol, hope this link may help:
iec1107
Hello,
I am looking for 62056-21. Is it same with 1107
iec 1107 protokoll
ali_1can said:
Hello,
yes it is same as 1107.
