aswathymohan
Member level 4
Hi
I wann do create an form having button,textbox,serialport in visual c# 2010.My objective is when a button press the data coming from the serial port has to displayed in textbox.I copied a code from a tutorial.textbox is not showing anything,pl help..i am not familiar with c#.pl help.its urgent..here's is the code
Code C# - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 using System; using System.Collections.Generic; using System.ComponentModel; using System.Data; using System.Drawing; using System.Linq; using System.Text; using System.Windows.Forms; namespace ser1 { public partial class Form1 : Form { private string RxString; public Form1() { InitializeComponent(); } private void buttonStart_Click(object sender, EventArgs e) { serialPort1.PortName = "COM4"; serialPort1.BaudRate = 9600; serialPort1.Open(); if (serialPort1.IsOpen) { buttonStart.Enabled = false; buttonStop.Enabled = true; textBox1.ReadOnly = false; } } private void textBox1_KeyPress(object sender, KeyPressEventArgs e) { // If the port is closed, don't try to send a character. if (!serialPort1.IsOpen) return; // If the port is Open, declare a char[] array with one element. char[] buff = new char[1]; // Load element 0 with the key character. buff[0] = e.KeyChar; // Send the one character buffer. serialPort1.Write(buff, 0, 1); // Set the KeyPress event as handled so the character won't // display locally. If you want it to display, omit the next line. e.Handled = true; } private void DisplayText(object sender, EventArgs e) { textBox1.Text=RxString.Trim(); textBox1.Show="h"; } private void serialPort1_DataReceived(object sender, System.IO.Ports.SerialDataReceivedEventArgs e) { RxString = serialPort1.ReadExisting(); this.Invoke(new EventHandler(DisplayText)); } private void buttonStop_Click(object sender, EventArgs e) { if (serialPort1.IsOpen) { serialPort1.Close(); buttonStart.Enabled = true; buttonStop.Enabled = false; textBox1.ReadOnly = true; } } private void Form1_FormClosing(object sender, FormClosingEventArgs e) { if (serialPort1.IsOpen) serialPort1.Close(); } private void textBox1_TextChanged(object sender, EventArgs e) { } } }
