knowledge_Seeker1
Newbie level 6
I a newbie to c++ and Ns3 !
I want node 1 to send node 2 a packet where the data in that packet is of my choice . (
so i want to include in the packet , a message of 10 lines of string. I have this message saved in a file on my laptop.
So i did lots of research and Here are the things that I collected from this site :
The Packet in Ns3 contains a byte buffer.
The byte stores the serialized content of the chunks added to a packet.
The byte buffer is implemented as follows:
ok , so from this point onward i have NO idea how to make the buffer hold the 10 lines of string that I have in my file.
Please help. I have been stuck for 3 days
Edit/Delete Message
Code C++ - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 struct BufferData { uint32_t m_count; uint32_t m_size; uint32_t m_initialStart; uint32_t m_dirtyStart; uint32_t m_dirtySize; uint8_t m_data[1]; }; struct BufferData *m_data; uint32_t m_zeroAreaSize; uint32_t m_start; uint32_t m_size; BufferData::m_count // reference count for BufferData structure BufferData::m_size // size of data buffer stored in BufferData structure BufferData::m_initialStart // offset from start of data buffer where data was first inserted BufferData::m_dirtyStart // offset from start of buffer where every Buffer which holds a reference to this BufferData instance have written data so far BufferData::m_dirtySize // size of area where data has been written so far BufferData::m_data // pointer to data buffer Buffer::m_zeroAreaSize // size of zero area which extends before m_initialStart Buffer::m_start // offset from start of buffer to area used by this buffer Buffer::m_size // size of area used by this Buffer in its BufferData structure
Edit/Delete Message
