C programming of 16F877
MARWEN007
Junior Member level 2
I want to measure an effective value of an AC voltage with a 16F877 and display the result on the LCD voltage is a 400 vmax right I want to use this method since the value of voltage is variable I want to know is it possible to translate this formula C language??
N : nombre d’échantillons
Ui : valeur de l’échantillon i.
It can. Compute that into Numerical Analysis.
You must define how many sample you want. Then calculate that, is that square and total sum. But make sure the total sum is not exceed bit number you use.
