c programming in pic c
venuselectronics
india
hi all
i have started learning c, and embedded c programming
kindly tell me which books for above subject is good to read for beginner, i have downloaded several books from freebookspot.com, kindly tell me microcontroller project book for pic which have source code and schematic and descriptin of schematic and source code.
thanks
venus electronics
Well
C is C.
I suggest to read a book called C by Example, the low price edition by Cambridge.
Regarding embedded C, it is just extensions to the original library.
There are a couple of nice books can be found here https://www.futurlec.com/BooksPIC.shtml.
You didn't say which family of PIC that you wanted to target: 8-bit, 16-bit, dsPIC, 32-bit. I would highly recommend that you avoid 8-bit and older PIC devices, and instead target newer and wider instruction PICs. Even better suggestion, avoid all PIC's and target AVR or ARM (I'm sure this advice will get some heated replies).
thanks a lot, please provide some more information,so that i will study with confidence
venus electronics
