C program that makes PIC 16F877A wait until PORTD changes (HITECH HI-TIDE v3)
crocklip
Junior Member level 1
I am using a PIC for a project that Im working on at the moment. I need to program it (in C) to wait until PORTD changes, ie. when any bit in portD toggles.
Maybe an interrupt?
Thanks for the help
simpe C question
It would be sensible if you mention your C compiler too....
Re: simpe C question
Hi!
Mention the compiler and also the microcontroller that u wish to use.
Regards.
for 8051->u use keil c cross compiler..
for motorola 68000->use tasking compiler.....
U need to be polling for the portd bits , each iteration check for the change.
If there is no change then sleep few msecs.
The PIC is 16F877A and I'm using the HITECH HI-TIDE V.3 compiler
Thanks
