nirmal_rockin
Junior Member level 2
Hi...
I'm in urgent need.. i got this program somewher from the net and i've edited it for my line follower which i'm building....but the program shows some errors(the microcontroller used is atmega16) and i'm totally confused about the header files 'delay.h' and 'mega16.h' i tried using the header files provided in the avr_libc..but it shows several errors.... can anyone help me resolving this problem...
how can i create an errorless program....
pls help me..... i dono much about microcontrollers....
thank you...
thank you...
Project : Line Follower
Chip type : ATmega16
Program type : Application
Clock frequency : 7.372800 MHz
Memory model : Small
External SRAM size : 0
Data Stack size : 256
//#define debug 1
#include <mega16.h>
#include <delay.h>
#ifdef debug
#include <stdio.h>
#endif
#define FWD 0xAA
#define REV 0x55
#define R 0x22
#define L 0x88
#define CW 0x99
#define CCW 0x66
#define STOP 0x00
#define B 0xFF
#define RSPEED OCR1AL
#define LSPEED OCR1BL
#define SPEED0 255
#define SPEED1 0
#define SPEED2 0
#define SPEED3 0
#define MAX 3
#define HMAX 1
void move (unsigned char dir,unsigned char delay,unsigned char power);
unsigned char i,rdev,ldev,ip,delay,dir,power,dirl,history[MAX],hcount=0,rotpow;
#ifdef debug
unsigned char rep=0,prev=0;
#endif
void main(void)
// Input/Output Ports initialization
// Port A initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
PORTB=0x00;
DDRB=0x00;
// Port C initialization
PORTC=0x00;
DDRC=0xFF;
// Port D initialization
// Func7=In Func6=In Func5=Out Func4=Out Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=0 State4=0 State3=T State2=T State1=T State0=T
PORTD=0x00;
DDRD=0x30;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=FFh
// OC0 output: Disconnected
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Timer/Counter 1 initialization
// Clock value: 921.600 kHz
// Mode: Fast PWM top=00FFh
// OC1A output: Non-Inv.
// OC1B output: Non-Inv.
// Noise Canceler: Off
// Input Capture on Falling Edge
TCCR1A=0xA1;
TCCR1B=0x0A;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0xFF;
OCR1BH=0x00;
OCR1BL=0xFF;
// Timer/Counter 2 initialization
// Clock value: Timer 2 Stopped
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
#ifdef debug
// USART initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART Receiver: On
// USART Transmitter: On
// USART Mode: Asynchronous
// USART Baud rate: 57600
UCSRA=0x00;
UCSRB=0x18;
UCSRC=0x86;
UBRRH=0x00;
UBRRL=0x07;
#endif
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
while (1){
#ifdef debug
if(rep<255)
rep++;
if(prev!=PINA) {
prev=PINA;
printf("%u\r",rep);
for(i=0;i<8;i++)
printf("%u\t",(prev>>i)&0x01);
rep=0;
#endif
if(PINA!=255){
rotpow=255;
ldev=rdev=0;
if(PINA.3==0)
rdev=1;
if(PINA.2==0)
rdev=2;
if(PINA.1==0)
rdev=3;
if(PINA.0==0)
rdev=4;
if(PINA.4==0)
ldev=1;
if(PINA.5==0)
ldev=2;
if(PINA.6==0)
ldev=3;
if(PINA.7==0)
ldev=4;
if(rdev>ldev)
move(R,0,195+12*rdev);
if(rdev<ldev)
move(L,0,195+12*ldev);
if(rdev==ldev)
move(FWD,0,200);
else {
for(i=0,dirl=0;i<MAX;i++) {
if(history==L)
{dirl++;}
if(rotpow<160) {rotpow=160;}
if(rotpow<255) {rotpow++;}
if(dirl>HMAX)
{move(CW,0,rotpow);}
else
{move(CCW,0,rotpow);}
void move (unsigned char dir,unsigned char delay,unsigned char power) {
PORTC=dir;
if(dir==L || dir==R) {
hcount=(hcount+1)%MAX;
history[hcount]=dir;
LSPEED=RSPEED=255;//power;
//delay_ms(delay);
