[AVR] C Language Code Logic
Titus Manoj Kumar
Junior Member level 2
Sriperumpudur, Tamil Nadu
Hi all,
I ve a question..
I've two int values (0 to 9) in two variables h_i and h_j
based on that values am going to switch On/Off any device.(ex.led)
ex: if the value is 22 ; led should blink 22 times.
What's the logic should we use in the code?
Thanks.
Code C - [expand]
for(i = 0; i = h_i; i++){
        LED = 1;
    Delay_ms(500);
        LED = 0;
        Delay_ms(500);
If h_i = 22 then LED will blink 22 times.
Hi.,
Thanks for the reply.
But what if suppose the value (22) in which 1st 2 is in h_i and second 2 is in h_j.?
Plz do see this image
https://obrazki.elektroda.pl/4758763400_1390814113.jpg
The value will be entered in the LCD using the switches.
Depending on the values the relays should be switched ON/OFF.
Pls do help.
Thank you.
If one is the tens digit and the other the units digit you can either do a units loop inside a tens loop or combine them into a single number.
For example "NewVariable = (h_i * 10) + h_j;" which makes NewVariable equal to 22 using your numbers as an example.
Incidentally, you should NEVER drive relay coils directly from a microcontroller! It almost certainly can't provide enough current and in any case would be damaged by back-EMF as the relay turns off.
Brian.
