C++ - inserting images into files
C++
Junior Member level 3
code for inserting image in dev c++
Hi, I've got a simple command line program like this:
#include <iostream>
#include <fstream>
using namespace std;
int main () {
    ofstream file;
    file.open ("Test.doc");
    file << "This is an image inserted into this file with C++!" << endl;
    // Somehow insert an image below that line <-- dont know how
    file << "This line was inserted after the image!";
    file.close ();
    cout << "Press ENTER to exit . . .";
    cin.get ();
    return 0;
What code can I put into that commented line to insert the picture into that file?
Any help is appreciated....
Platform: Windows (XP)
Compiler: Dev-C++/MSVC++
Re: C++ - inserting images into files . . .
If your using a DOC file (ie., Microsoft Word) then I think the definition of the format is available. You might be able to find out how to create a DOC file here http://www.wotsit.org/.
- Jayson
that wasn't really helpful, when i write to the file like that, it saves it as plain text, but it can still support advanced features since it's a .doc file
i just need some function to copy and paste a picture in the file
The easiest way to acomplish this could be using OLE Automation ...
You can use this VB code to figure C++ code using automation
    Selection.InlineShapes.AddPicture FileName:= _
        "D:something.jpg", LinkToFile:=False, SaveWithDocument:=True
    Selection.TypeParagraph
    Selection.TypeText Text:="This image was inserted ...."
    ActiveDocument.Save
