I am learning C++on my own by reading the book "Programming principles and practice using C++ by Bjarne Stroustrup"
They have started with a basic Hello world program.
//This program outputs the message "Hello, World to the monitor
#include"std_lib_facilities.h"
int main() //C++ programs start by executing the function main
cout<<"Hello, World! \n"; //output "Hello,World! "
return 0;
I am getting this error [Error] std_lib_facilities.h: No such file or directory
Please give me your comments about this error
Thanks
Perhaps the path of this library is not proerly set on your system variables.
As a quick turn around, you could either: Make a search of the std_lib_facilities.h file in your entire disk and add the folder before the file name, or simply copy this file from where it was found to the project folder.
You should add the #include"std_lib_facilities.h" header file . The compiler cant find the #include"std_lib_facilities.h" file .So you manually insert that one .
Look here may be helpful**broken link removed**
