C++ Hello world program error
moin_moin
Newbie level 3
Hello
I am learning C++on my own by reading the book "Programming principles and practice using C++ by Bjarne Stroustrup"
They have started with a basic Hello world program.
//This program outputs the message "Hello, World  to the monitor
#include"std_lib_facilities.h"
int main() //C++ programs start by executing the function main
cout<<"Hello, World! \n"; //output "Hello,World! "
return 0;
I am getting this error
[Error] std_lib_facilities.h: No such file or directory
Please give me your comments about this error
Perhaps the path of this library is not proerly set on your system variables.
As a quick turn around, you could either: Make a search of the std_lib_facilities.h file in your entire disk and add the folder before the file name, or simply copy this file from where it was found to the project folder.
I think the way are called the library depends on your Compiler and if you not use same as used in that book maybe they give you errors.
However, the general way to write it is like this:
#include <cstdlib>
[B]#include <iostream>[/B]
[B]using namespace std;[/B]
int main()
cout<<"Hello, world"<<endl;
return 0;
NOTE: in C++ usually is used cstdlib instead of stdlib.h but it works however
You should add the #include"std_lib_facilities.h" header file . The compiler cant find the #include"std_lib_facilities.h" file .So you manually insert that one .
Look here may be helpful**broken link removed**
Ya this is the only reason I found. Thanks
