Nov 26, 2006 #1 D dangoren Newbie level 1 Joined Nov 26, 2006 Messages 1 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,290 Hi, I am considering using C++ for the development of a hardcore embedded wireless chip? The CPU will probably be Cortex M3. Does anyone have some insight as to the pros & cons, benefits, risks... Thanks
Nov 27, 2006 #2 sci-3d Full Member level 2 Joined Aug 25, 2006 Messages 125 Helped 7 Reputation 14 Reaction score 0 Trophy points 1,296 Location USA Activity points 1,891 I think C is enough for Embedded Systems.
Dec 8, 2006 #3 T txdx2005 Member level 1 Joined Jul 15, 2006 Messages 37 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,610 I think so
Nov 29, 2007 #4 W waterman Member level 5 Joined Mar 27, 2002 Messages 80 Helped 2 Reputation 6 Reaction score 2 Trophy points 1,288 Activity points 562 For Cortex M3, C++ may be as good as C. Use it if you are familiar with C++. The key point is if the compiler could produce a good machine code. The architecture of Cortex M3 is adapted to use the high-level programming language.
Nov 30, 2007 #5 P psmll Member level 4 Joined Apr 9, 2007 Messages 74 Helped 4 Reputation 8 Reaction score 0 Trophy points 1,286 Activity points 1,803 I recommend using only C, but you can use C++ if performance is not very important. Many times the pure performance is not the most important, so for this cases the C++ is better to work with.
Dec 1, 2007 #6 funnynypd Banned Joined May 9, 2007 Messages 436 Helped 48 Reputation 100 Reaction score 25 Trophy points 1,308 Location USA & Canada Activity points 0 Anyone knows a good C++ compilor for this processor?
