Code C - [expand ] 1
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
#include<reg51.h>
#define dataport P1 //lcd 16x2 data port
#define cont_port P2
sbit rs = cont_port^ 0 ; //lcd rd pin @ P2_0
sbit rw = cont_port^ 1 ; //lcd rw pin @ P2_1
sbit en = cont_port^ 2 ; //lcd en pin @ P2_2
sbit input = P3^ 3 ; //ir pin connected to Port3_3
int i;
int cmd, add, flip, val, val1, nflip;
void delay1( ) //delay of 3.024msec
TMOD= 1 ;
TL0= 0x1D ;
TH0= 0xF5 ;
TR0= 1 ;
while ( TF0 == 0 ) ;
TR0= 0 ;
TF0= 0 ;
void delay( ) //delay of 1.658msec
TMOD= 1 ;
TL0= 0x07 ;
TH0= 0xFA ;
TR0= 1 ;
TR0= 0 ;
TF0= 0 ;
void mdelay( int msec)
while ( msec != 0 )
TMOD= 1 ;
TL0= 0x1D ;
TH0= 0xF5 ;
TR0= 1 ;
TR0= 0 ;
TF0= 0 ;
msec--;
void lcd_cmd( unsigned char item) //Function to send command to LCD
dataport = item;
rs= 0 ;
rw= 0 ;
en= 1 ;
delay1( ) ;
en= 0 ;
return ;
void lcd_data( unsigned char item) // Function to send data to LCD
dataport = item;
rs= 1 ;
rw= 0 ;
en= 1 ;
delay1( ) ;
en= 0 ;
return ;
void lcd_data_string( unsigned char * str) // Function to send string to LCD
int i= 0 ;
while ( str[ i] != '\0 ' )
lcd_data( str[ i] ) ;
i++;
delay1( ) ;
return ;
void lcd_data_int( int time_val) // Function to send number to LCD
int int_amt;
int_amt= time_val/ 10 ;
lcd_data( int_amt+ 48 ) ;
int_amt= time_val% 10 ;
void tog( ) //calculate flip bit
flip= input;
void address( ) //calculate the address
for ( i= 0 ; i< 5 ; i++ )
add= ( add<< 1 ) | input;
delay( ) ;
void command( ) //calculate the command
for ( i= 0 ; i< 6 ; i++ )
cmd= ( cmd<< 1 ) | input;
delay( ) ;
void value( )
if ( cmd >= 0 && cmd <= 9 )
val= cmd;
// val=val*10+cmd;
else
lcd_cmd( 0xcb ) ;
lcd_data_string( "NV" ) ;
return ;
lcd_cmd( 0xcb ) ;
lcd_data_int( val) ;
void display_init( ) //display init
lcd_cmd( 0x38 ) ;
delay( ) ;
lcd_cmd( 0x0E ) ;
delay( ) ;
lcd_cmd( 0x01 ) ;
delay( ) ;
lcd_cmd( 0x06 ) ;
delay( ) ;
lcd_cmd( 0x80 ) ;
delay( ) ;
lcd_data_string( "ADD:" ) ;
lcd_cmd( 0x89 ) ;
delay( ) ;
lcd_data_string( "FLIP:" ) ;
lcd_cmd( 0xC0 ) ;
delay( ) ;
lcd_data_string( "CMD:" ) ;
lcd_cmd( 0xC9 ) ;
delay( ) ;
lcd_data_string( "V:" ) ;
void display_value( ) //display value
lcd_cmd( 0x84 ) ;
delay( ) ;
lcd_data_int( add) ;
lcd_cmd( 0x8E ) ;
delay( ) ;
lcd_data_int( flip) ;
lcd_cmd( 0xc4 ) ;
delay( ) ;
lcd_data_int( cmd) ;
void main( )
display_init( ) ;
while ( 1 )
add= 0 ;
cmd= 0 ;
while ( input == 1 ) ;
delay1( ) ;
tog( ) ;
delay( ) ;
address( ) ;
command( ) ;
nflip= flip;
if ( add == 0 && ( flip== 1 || flip == 0 ) )
display_value( ) ;
//mdelay(1);
value( ) ;
work fine with the 8051 controller. Adjust the timer to create delay for particular controller
Thanks
Ashwin Guru.
