C codes for decoding RC5 signals using PIC microcontoller
My code is working ok.
With the lower prescale I had to increase the timeout in two functions.
/*--- Timer 4 one shot Interrupt ---*/
void __attribute__((__interrupt__, no_auto_psv)) _T4Interrupt(void)
  if(!Decoder.error)
    if(Decoder.bit_counter == 0x0b){
      save_data(0);
    RC5_Code.address = (Decoder.rc_data >> 6) & 0x001f;
    RC5_Code.command = Decoder.rc_data & 0x003f;
    RC5_Code.toggle = (Decoder.rc_data >> 11) & 0x0001;
    RC5_Code.valid = 1;
  IFS1bits.T4IF = 0;
  IEC1bits.T4IE = 0;
  T4CONbits.TON = 0;
  [B]PR4 = 0x2000;		  !!!!!! increase timeout[/B]
  Decoder.State = START_S;
/*--- Initialise Timer 4 (Used as RC timer) ---*/
static void init_timer_4(void)
  T4CON = 0;
  IPC6bits.T4IP = 6;    /* High priority */
  [B]T4CONbits.TCKPS = 1;  /* Prescale 1:8 */ [/B]
  [B]PR4 = 0x2000;          /* Time out */   !!!!!! increase timeout   [/B]
  IFS1bits.T4IF = 0;
  IEC1bits.T4IE = 0;    /* Interrupt enable bit */
  T4CONbits.TON = 0;
/*--- End of File ---*/
This code is working ok.
#include "rc5_decoder.h"
_CONFIG1( JTAGEN_OFF & GCP_OFF & GWRP_OFF & COE_OFF & FWDTEN_OFF & ICS_PGx2)
_CONFIG2( FCKSM_CSDCMD & OSCIOFNC_ON & POSCMOD_NONE & FNOSC_FRC)
/*--- RC5 infra red codes ---*/
#define RC5_ADDRESS     20U
#define STOP            54U
#define PLAY            53U
#define PAUSE           48U
#define NEXT_TRACK      32U
#define PREV_TRACK      33U
#define SCAN_FORWARDS   52U
#define SCAN_BACKWARDS  50U
/*--- Program entry ---*/
int main(void)
  init_rc5_decoder(); /* Initialise decoder */
  TRISA = 0;
  AD1PCFG = 0xffff;
  while(1)
    if(RC5_Code.valid)
      PORTA = RC5_Code.command;
      RC5_Code.valid = 0;
Wow..Now it's working like a charm.....Thanks aaaaaaaaaa lot btbass...!!...
For 8mhz..Prescale 1:64
T4CONbits.TCKPS = 2;
Good, now its working here are the files for future users.
  • Rc5_C30.zip
@btbass...
Now, I am using this code to display VOLUME UP n DOWN using 2x16 LCD.....I have used PLAY for VOLUP and STOP for VOL DOWN...Can u please check my code? I am getting some errors...
Attache work space...Thanks in Advance...!!
  • Rc5_Decoder.zip
I think you have posted the wrong code???
Ups..This one..All .c and .h files
  • rc5_decoder.zip
Change the rc5_decoder.h file for this one.
#ifndef RC5_DECODER_H
#define RC5_DECODER_H
/*--- RC code structure ---*/
typedef struct
  unsigned char toggle;
  unsigned char address;
  unsigned char command;
  unsigned char valid;
  }RC5_CODE;
extern volatile RC5_CODE RC5_Code;
/*--- Function prototypes ---*/
void init_rc5_decoder(void);
#endif
You have two functions both called write?
You need to rename one of them.
Getting Error like
In file included from main.h:2,
from lcd.c:1:
rc5_decoder.h:21:7: warning: no newline at end of file
In file included from main.h:5,
from lcd.c:1:
conu2.h:24:7: warning: no newline at end of file
In file included from main.h:7,
from lcd.c:1:
volume.h:10:7: warning: no newline at end of file
lcd.c: In function 'uwrite':
lcd.c:5: error: syntax error before '{' token
lcd.c:107:2: warning: no newline at end of file
void write(int handle, void *buffer, unsigned int len); ????
missing semicolon in lcd.h
Thanks btbass...SOLVED...!!!
Now getting display..I have removed extra files..
what this statement do?
The toggle bit is for detecting a new keypress.
If you press and hold a key, the code is repeatably sent, but the toggle bit does not change.
If you let the key go, then repress it, the toggle bit changes to indicate a new keypress.
So, every time you press a new key, the toggle bit toggles.
You can use the toggle bit so you dont keep repeating the same command if someone is holding a key down.
psuedo code
unsigned char last_toggle;
if(code_valid)
  if(toggle != last_toggle)
    do command;
    last_toggle = toggle;
@btbass...Yh..It's really cool...I adopted..!!
I have written an interrupt driven RC5 decoder for CCS C compiler.
You can get it here:
Regards!
where i wrong
/*** FILEHEADER ****************************************************************
 *    FILENAME:    RC5 IR Remote.c
 *    DATE:        07.10.2011
 *                       Uses RC5 driver by Christian Stadler
 *    DESCRIPTION: IR Remote, Controls 8 Relays
 *    16F676 Configuration, I=Input, O=Output
 *                         _________
 *                   Vdd   | 1  14 |  Vss
 *       (O) xxx <-- RA5   | 2  13 |  RA0 --> LED (O)
 *       (I)  IR --> RA4   | 3  12 |  RA1 --> RL7 (O)
 *                  MCLR   | 4  11 |  RA2 --> RL8 (O)
 *       (O) RL6 <-- RC5   | 5  10 |  RC0 --> RL1 (O)
 *       (O) RL5 <-- RC4   | 6   9 |  RC1 --> RL2 (O)
 *       (O) RL4 <-- RC3   | 7   8 |  RC2 --> RL3 (O)
/*** HISTORY OF CHANGE *********************************************************
 *   07.10.2011 Initial Version
#include <RC5 IR Remote.h>
#include "types.h"
/* --- RC5 driver configuration --- */
#define RC5_DATA_PIN          PIN_A4        /* IR sensor (SFH5110-36) connected to RB1 */
#define RC5_TICKS_PER_MS      (1000/32)      /* timer increments every 31.25 us */
                                            /* i.e. around 1000 ticks per millisecond */
#define RC5_GetTimer()        get_timer0()  /* timer0 shall be used for RC5 decoding */
/* --- macros to switch on/off LED --- */
#define Led_On()        output_high(PIN_A0)
#define Led_Off()       output_low(PIN_A0)
/* RC5 driver include */
#include <RC5_driver.h>
//PORT C Register = 0x07
//PORT A Register = 0x05
#BIT RL1 = 0x07.0
#BIT RL2 = 0x07.1
#BIT RL3 = 0x07.2
#BIT RL4 = 0x07.3
#BIT RL5 = 0x07.4
#BIT RL6 = 0x07.5
#BIT RL7 = 0x05.1
#BIT RL8 = 0x05.2
 Key Codes
#define RC5_NUMERIC_KEY_0 0x00 /* NUMERIC KEY 0 */
#define RC5_NUMERIC_KEY_1 0x01 /* NUMERIC KEY 1 */
#define RC5_NUMERIC_KEY_2 0x02 /* NUMERIC KEY 2 */
#define RC5_NUMERIC_KEY_3 0x03 /* NUMERIC KEY 3 */
#define RC5_NUMERIC_KEY_4 0x04 /* NUMERIC KEY 4 */
#define RC5_NUMERIC_KEY_5 0x05 /* NUMERIC KEY 5 */
#define RC5_NUMERIC_KEY_6 0x06 /* NUMERIC KEY 6 */
#define RC5_NUMERIC_KEY_7 0x07 /* NUMERIC KEY 7 */
#define RC5_NUMERIC_KEY_8 0x08 /* NUMERIC KEY 8 */
#define RC5_NUMERIC_KEY_9 0x09 /* NUMERIC KEY 9 */
/* Interrupt_RA                                                              */
/* Port A change interrupt service routine.                                  */
/* Used to decode RC5 IR signal.                                             */
#INT_RA
void Interrupt_RA(void)
   Led_On();
   RC5_InterruptHandler();
   Led_Off();
   clear_interrupt(INT_RA4);
/* main        */
/* Configures timer0 as time base for RC5 decoding and enables port A        */
/* interrupt on change.                                                      */
/* Main loop checks if a RC5 code has been received and processes the code   */
/* in the switch-case statement                                              */
/* NOTE: Currently it only works if PIC is reset after programming? */
 void main()
   unsigned int16 rc5code;
   unsigned int rc5cmd;
   setup_comparator(NC_NC);      // All Ports Digital
    /* FOSC/4 is timer source */
    /* Original Configuration:
    /* FOSC = 20MHz => 5MHz, i.e. timer increment every t = 1/(FOSC/4) = 200ns */
    /* with prescaler of 128 timer will increment every 25.6us */
    // 16F676 Running at Internal 4 Mhz Configuration:
    // Timer0 increments every 1 us (4 Mhz/4 = 1 Mhz)
    setup_timer_0(RTCC_INTERNAL | RTCC_DIV_32);
    // TRIS Ports set by #use fixed_io in RC5 IR Remote.h
    /* read port A to clear mismatch condition */
    input_a();
    /* configure port A interrupt on change */
    clear_interrupt(INT_RA);        /* clear port A interrupt flag */
    enable_interrupts(INT_RA);     /* enable RA4 interrupt on change */
    /* global interrupt enable */
    enable_interrupts(GLOBAL);
    // Main Loop
    while (1)
      /* check if new data is available */
        if (RC5_CodeReady())
            /* get code */
            rc5code = RC5_GetCode();
            // Extract command from RC5 code
            rc5cmd = RC5_GetCmd(rc5code);
           switch (rc5cmd)
               case RC5_NUMERIC_KEY_0:
                    RL1 = ~RL1;
                    break;
                 case RC5_NUMERIC_KEY_1:
                    RL2 = ~RL2;
                    break;
                 case RC5_NUMERIC_KEY_2:
                    RL3 = ~RL3;
                    break;
                 case RC5_NUMERIC_KEY_3:
                    RL4 = ~RL4;
                    break;
                 case RC5_NUMERIC_KEY_4:
                    RL5 = ~RL5;
                    break;
                 case RC5_NUMERIC_KEY_5:
                    RL6 = ~RL6;
                    break;
                 case RC5_NUMERIC_KEY_6:
                    RL7 = ~RL7;
                    break;
                 case RC5_NUMERIC_KEY_7:
                    RL8 = ~RL8;
                    break;
                 case RC5_NUMERIC_KEY_8:
                    RL1 = 1;
                    RL2 = 1;
                    RL3 = 1;
                    RL4 = 1;
                    RL5 = 1;
                    RL6 = 1;
                    RL7 = 1;
                    RL8 = 1;
                    break;
                 case RC5_NUMERIC_KEY_9:
                    RL1 = 0;
                    RL2 = 0;
                    RL3 = 0;
                    RL4 = 0;
                    RL5 = 0;
                    RL6 = 0;
                    RL7 = 0;
                    RL8 = 0;
                    break;
        /* this function increments the RC5 timeout timer */
        /* NOTE: Decoding will also work without calling this function, but */
        /*       it could happen that RC5 codes are sometimes not getting */
        /*       recognized because of decoding state machine stucks due */
        /*       to erroneous RC5 signal. */
        RC5_TimeoutIncrement();
pl guied me
Re: rc5 code yager
HI..i have a problem.. i have a project with name " designing an application (in MPLAB IDE) for interfacing with a remote IR signal (display key codes pressed)". Accessories: PIC18F4520, TSOP 1136, remote control PHILIPS (RC5 STANDARD ), MPLAB C18 COMPILER..;are 14 bits, start bit 1, start bit 2, toggle bit ,5 address,6 command ..How to read .. and how to display bits?pls if u can help me with the C CODE( main.c). an example please..waiting for your answer ..thanks
If you have a debugger, try a few break points to see whats going on.
I have the same Explorer board, I will try your code later today when I can and report back.
hey btbass, i got a code from this forum and is tat writen by u?
  • rc5_interrupt.zip
