c code to hex file convert pic 16F676
convert the [text] file to hex? why?
or do you mean convert the C code to machine language?
is there a reason for it?
Your code is for Hi-Tech PICC Compiler. Download the lite version of the Compiler from htsoft.com or download the 45 day evaluation version of the Compiler which will work in Pro mode with out limitations for 45 days but will work in lite mode after 45 days. The only difference between lite and Pro modes is that lite version doesn't have code optimizations and the .hex file generated by lite version will be bigger than the one obtained using Pro mode.
Also download MPLAB 8.92 from microchip which is free software.
Dear all I am not familiar hardware language I am 0 about PIC programing I have only PICKIT 2 for writing hex file into PIC. I also have MPLAB 8.92 from microchip website but not aware how can I convert this c file to hex file. kindly help
If possible copy the url of that page from the address bar of the browser and past it in your post using tags. [URL] your url [/URL ]. Remo...piled the code. You might need that settings.
  • PIC16F676 Stabilizer.rar
This is the 1st line in void main() function
Code C - [expand]
OSCCAL=_READ_OSCCAL_DATA();
and
Code C - [expand]
definition is missing. So you have to check the datasheet and set the bits of OSCCAL register as required for your project. Ask the code's author to provide full working code.
