C Code Programming Help With Keil uVision4
kpin414
Newbie level 2
Newbie level 2
Hello There!
I have c code program for a project "PC controlled scrolling message display" and compiling it with Keil uVision4. I am new with this C programming code and trying to debug the program errors and warnings. I have been debug all the errors, but stuck with a warning message which i am unable to debug and tried a lot to debug but no luck at all. Can somebody out there help me to debug and make it run this c code program. Attached is the c code file and uVision screenshot to be consider if any. Any help will be greatly appreciated.
Thanks A Lot.
  • C-code+Screen Shot.zip
first you should remove startup.s from your project if it is added as file.
attach uvision project file too so it will be easy to debug..
regards ANJ
regards ANJ
Hello ANJ! thank you very much for your suggestion. As stated in my post i am new with this coding scheme and its getting hard to me to understand easily. Can you please assist me in simple step-by-step process what i have to do first to debug the current warning and then next step. Could you please let me know where is the startup.s file and what is the code and where to add uvision project file. Can you please run and modify the attached c code at your end so that i can understand more clearly what i have to do. Once again thanks a lot for your valuable support.
