[General] c code for receiving 8 bit data from hyperterminal to 89c51
Sagar Shinde
Newbie level 3
Newbie level 3
i am doing home automation project but i dont know how to enable particular pin i.e P1.0 enable when 8 bit data is received
Description:
consider, when i send 10011101 from hyperterminal then only P1.0 pin is enabled
when i send 10111100 from hyperterminal then only P1.1 pin is enabled
please send me c code
which compiler you are using following explaination for 8051 and keil compiler.
first you have to define bit as
sbit pin1=P1^0;
sbit pin2=P1^1;
above main function.
then compare the recieved character with you data as you given
if(receiv_data == 0x9D)
	pin1 = 1;
else if (receiv_data == 0xBC)
	pin2 = 1;
sbit pin1=P1^0;
sbit pin2=P1^1;
	pin1 = 1;
	pin2 = 1;
thank you!!! i will try
#include<reg51.h>
sbit pin1=P1^0;
sbit pin2=P1^1;
void main(void)
unsigned char i;
unsigned char bit1[]="10101010";
unsigned char bit2[]="11110000";
unsigned char buff[8];
TMOD=0x20;
TH1=0xFD;
SCON=0x50;
TR1=1;
while(1)
while(RI==0)
for(i=0;i<8;i++)
buff=SBUF;
if(buff==bit1)
pin1=1;
else
pin2=1;
here is my code please suggest me what can i do to comparision between bit1 and receiving data from hyperterminat
#include<reg51.h>
sbit pin1=P1^0;
sbit pin2=P1^1;
void main(void)
unsigned char i;
TMOD=0x20;
TH1=0xFD;
SCON=0x50;
TR1=1;
while(1)
while(RI==0)
for(i=0;i<8;i++)
buff=SBUF;
if(buff==bit1)
pin1=1;
else
pin2=1;
here is my code please suggest me what can i do to comparision between bit1 and receiving data from hyperterminal
