[SOLVED] C# Bool Variable always false
rkt_167
Junior Member level 1
hi all,
I am comparing two strings:
Code C# - [expand]
bool d = (String.Equals(ethernetHeader.Source,staticForm.textBox1.Text.ToString()));
this statement is always false even in console both are same as below..
ethernetHeader.Source=00:25:64:4F:21:D9
textBox1.Text=00:25:64:4F:21:D9
any possible reason??
thanks,
should work - could you have spaces or a newline in one of the strings? try printing the strings e.g.
            Console.WriteLine(" '{0}' '{1}' {2}\n", ethernetHeader.Source, staticForm.textBox1.Text.ToString(), d);
you should then see if the strings are identical
also you don't require the ToSting() in staticForm.textBox1.Text.ToString()
staticForm.textBox1.Text returns a string
thanks horace1,
bool d = (String.Equals(ethernetHeader.Source.ToString(), staticForm.textBox1.Text.Trim()));
I used Trim() and now it is working fine.
