Burning Laser Diode Based Gas Lighter and Cigarette / Cigar Lighter
PowerKid
Junior Member level 1
Without GPS and Pressure Sensor it works as LPG Gas Lighter and or Cigarette / Cigar Lighter.
For LPG Gas Lighter there will be a small hole in which gas can enter.
Cast lightweight aluminium body which aslo acts as heatsink for Burning Lased Diode.
Tack Switch to turn On Laser Internally.
Super Capacitor Bank for quick charging and long lasting power and lightweight design.
Motorized Camera Shutter for adjustable side hole for Cigarette or Cigar.
Not more than 10 second charging time for super capacitors.
USB port for charging.
This device is for replacing and collapsing current Match Box Industry, Gas Lighter Industry and Cigarette Lighter Industry.
Warning:
This Burning Laser Device with BT, GPS and or Pressure Sensor, BT for configuring destination GPS location can be used for exploding ethanol bombs, plane fuel tanks, all kinds of non e-Vehicle fuel tanks, burst tyres/tubes of vehicles, explode LPG, Petrol, Deisel tankers, etc,... based on GPS location, fuel tank pressure, etc,...
So, use it cautiously.
I don't take the responsibility of negative harardous aspects of the Gas lighter Cigarette Lighter design.
Full c code coming in 1 or 2 days.
  • GPSPrABLI.PDF
Including use of the products it lights, I presume. :eek:
Yes, but my burning gas lighter and cigarette lighter are safe for eyes without anti-laser covering because laser beam will not bend and laser will not come out of enclosure. Just from laser diode to internal end of enclosure there will be just say 1 cm distance. Small non adjustable side hole for gas lighter.
The Burning Laser based Gas lighter and Cigarette lighter with Red or Infrared lasers with side hole in enclosure is not so dangerous but based on this if GPS based Infrared 5W or 7W supercapacitor based Burning laser keychains are made then maniacs might use it with or without eye tracking technology to burn cornea and retinas of beautiful girls, vehicle drivers to make accidents, they can ignite the clothes of people from a distance of say 500 meters. So, be careful.
