volney
Newbie level 1
building a audio anplifier
Design an audio amplifier system ( with components of your choice from problem1) with the following specifications:
(a) Mid frequency voltage gain of at least 100, variable
(b) Low frequency cutoff F1 of 50 Hz ( with a roll off 40 db/decade to lower frequencies
(c) High frequency cutoff F2 of 5Khz ( with a roll off 40db/decade to higher frequencies
(d) Input impedance Rin = 2k; Output impedance Rout = 2K
(e) Study the response at Load RL varying from 20K to 2K in steps of 2K
Components from problem 1
Diodes ( Normal, Schotky, Zener and Varactor Diodes)
Bipolar Transistors (NPN & PNP)
OP.Amps
FETs ( JFETs N-gate and P-gate; MOSFETs: N Channel and P Channel)
OP.Amps
