BUFFERS VS CLOCK BUFFERS
praneshcn
Member level 5
What is differeence B/W normal BUf and CLK BUF?
prithivikumars
Member level 2
hi,
The clock buffers are designed with some special property like high drive strength and less delay. Because clock net is the more fanout and longest running net. Even you can use the normal buffers in the clock path.
Prithivi.
aaronkong
The rise & fall time is almost the same of the CLKBUF, it can min the skew for CTS.
praneshcn
Member level 5
hi ,
wat exactly makes the clk buf to drive to minimixe skew. y cant a normal buffer do it?
onlymusic16
Full Member level 2
Normal buffers are designed with p/n ratio such that sum of rise delay and fall delay is minimum (atleast for high speed libraries) whereas Clock buffers have equal rise and fall slew rates. Reason for doing this is to prevent duty cycle of clock signal from changing when it passes through a chain of clock buffers.
santuvlsi
Member level 4
dear friend,
In clock buffer we are unable to alter the rise time, fall time, clock period once if it designed to a particular period or frequency
whereas
Normal buffers we are able to alter to our wish.
Santu
