kakoee
Newbie level 3
Buffer Insertion Problem
I am trying to insert buffer (repeater) on a specefic net in Synopsys IC compiler. I have some issues about that:
1- in order to find the optimum delay and the optimum number of buffers, I need to know the exact amount of Resistance and Capacitance of teh buffer. but I could not find the R and C of the Buffer cells in the .lib file. I mean the R and C that I can use in the Rabay's book formula as the R and C of repeater
I use TSMC 65 nm.
2- I dont know which buffer I should select from the library. there are a number of buffers. I know that I should gradually increase the size of buffer. but my problem is the size of first buffer. is there an yformual that give me size of first buffer based on the wire's Length, R and C.
3- how Can I calculate the optimum delay of buffer insertion for each wire with the length of L and R and C , if the capacitance of the driver is 0(Zero)
I use TSMC 65 nm.
