schouten_tjeerd
Newbie level 5
I can't get the boundary scan to detect my devices. I have a homemade board with a Xilinx Spartan 3E (xc3s100e) and a Xilinx PROM attached (XCF01SVOG20). The JTAG device I use is a Digilent XUP USB-JTAG Programming Cable. The scan only finds one device instead of two and it is is labeled "unknown". A popup is displayd: "Unknown device query - Do you have a BSDL or BIT file for this device?".
Here is the output:
// *** BATCH CMD : setCable -port usb21 -baud 750000
Connecting to cable (Usb Port - USB21).
Checking cable driver.
Driver file xusb_emb.sys found.
Driver version: src=1029, dest=1029.
Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS 12:35:07, version = 811.
Cable PID = 0008.
Max current requested during enumeration is 74 mA.
Type = 0x0004.
Cable Type = 3, Revision = 0.
Setting cable speed to 750 KHz.
Cable connection established.
Firmware version = 1302.
File version of D:/Xilinx/10.1/ISE/data/xusb_xlp.hex = 1302.
Firmware hex file version = 1302.
Type = 0x0004.
ESN option: 00000000000000.
PLD file version = 0012h.
PLD version = 0012h.
Type = 0x0004.
Attempting to identify devices in the boundary-scan chain configuration...// *** BATCH CMD : Identify
PROGRESS_START - Starting Operation.
Identifying chain contents ....INFO:iMPACT:1588 - '1':The part does not appear to be Xilinx Part.
'1': : Manufacturer's ID =Unknown , Version : 14
INFO:iMPACT:501 - '1': Added Device UNKNOWN successfully.
done.
PROGRESS_END - End Operation.
Elapsed time = 0 sec.
// *** BATCH CMD : identifyMPM
Any ideas?
Here is the output:
Cable PID = 0008.
Type = 0x0004.
Type = 0x0004.
Type = 0x0004.
done.
Any ideas?
