waseem said:Hi!
Can i ask as to why do you want to use a bootloader of that particaular baud rate?
If you want to use the serial port later in your code then it is not necessay for the baud rate of the bootloader to be the same as that of the baud rate that you want to use in your own code.
Regards.
waseem said:Hi!
I will try to help you with that but why donot you use this bootloader. It has been designed for PIC16F877/16F877A. I have been using it for the past 6 months.
Regards.
waseem said:Hi!
It is in the folder "Downloader Windows In Delphi" in the zip file that i have posted. Its name is "PICdownloader.exe".
You can also find all this stuff at the site
www.microchipc.com
Best Regards.
