Register Log in
Bootloader designed for PIC16F877/16F877A
ryusgnal
Malaysia
Bootloader Hex file
Who have PIC16F877A bootloader for 20MHz clock and 9600 baud rate? can anyone upload it here.
Thank you.
waseem
Full Member level 5
Pakistan
Re: Bootloader Hex file
Hi!
Can i ask as to why do you want to use a bootloader of that particaular baud rate?
If you want to use the serial port later in your code then it is not necessay for the baud rate of the bootloader to be the same as that of the baud rate that you want to use in your own code.
Regards.
ryusgnal
Malaysia
waseem said:
Hi!
Regards.
that means I can use different baud rate for bootloader and serial port communication?
waseem
Full Member level 5
Pakistan
Hi!
Yes ofcourse you can do that. The bootloader is a seprate program that is executed at start up and waits for a certain response from the serial port to start working. If it does not get that response then it switches to your code. So you can use the serial port at a baud rate that you desire irrespective of the baudrate of the bootloader.
Regards.
ryusgnal
Malaysia
I have download bootloader asm file from tiny bootloader. I want to change some configuration of the device from pic16f873A to pic16f877A. but when I try to build hex file, there is an error maybe because I'm not familiar with MPLAB. can anybody build it for me? or teach me how to build it? attached is the asm file.
waseem
Full Member level 5
Pakistan
Hi!
I will try to help you with that but why donot you use this bootloader. It has been designed for PIC16F877/16F877A. I have been using it for the past 6 months.
Regards.
waseem
Full Member level 5
Pakistan
Hi!
Here is your orignal file with complete compiled project.
Regards.
ryusgnal
Malaysia
Bootloader Hex file
Thanks so much Waseem......
ryusgnal
Malaysia
waseem said:
Hi!
Regards.
What is the sotware u use to load the code?
waseem
Full Member level 5
Pakistan
Hi!
It is in the folder "Downloader Windows In Delphi" in the zip file that i have posted. Its name is "PICdownloader.exe".
You can also find all this stuff at the site
www.microchipc.com
Best Regards.
ryusgnal
Malaysia
waseem said:
Hi!
www.microchipc.com
Best Regards.
Thank you
Toggle Sidebar
