Bootloader and user code relocating?
UroBoros
Advanced Member level 2
Cochin - India
Hai
This is the Bootloader I am using or trying to use form PIC 18F452.
The bootloader is downloading the user code successfully.
But my code is not running.
Seems my code vectoring may be wrong.But cant find the method.
can anybody go through the bootloader asm attached and suggest me how to vector user code for this.
Thanks
picstudent
jshroff
Hi Post your actual program looking at the bootloader source looks like your actal program needs to start with a GOTO PROGSTART instruction.
The bootloader will look for this and patch your program accordingly.
    UroBoros
UroBoros
Cochin - India
Hai
PROGSTART? I think it is a label in bootloader code. Is it relevent in my application?
My code starts with like this
org 00h
goto start
start
call port_ini
call timer_ini
goto mainline
mainline
nop
goto mainline
Where I should place my start vector?
the bootloader seems to reside at the extereme end of programe memory
also in 18 series can we start on HS mode and later switch on to PLL mode?
or will start with PLL only if PLL is to be used?
thanks
picstudent
jshroff
Picstudent said:
Hai
org 00h
goto start
start
call port_ini
call timer_ini
goto mainline
mainline
nop
goto mainline
thanks
picstudent
This looks OK, the bootloader will look for the first 4 bytes GOTO START and place them in the right location, this code looks like it will work correctly do yo have a way to test it without the bootloader? The start vector is correct, and will be relocated appropriately.
    UroBoros
UroBoros
Cochin - India
Hai
Thanks for the reply.
I have checked the code with ICD without bootloader.It is ok in that mode.
But in bootloader mode,it detects the bootloader ,downloads the code successfully and able to download agin also,Seems bootloader not corrupted and still in control.
But my code, it cant be seen anywhere!
Actually I have changed the asm for bootloader to suit my crystal frequency of 10mhz. It seems ok because both are communicating each other and if we pressed reset during a transfer it aborts also. All ok it seems for me.
Is there any pin pulling up for this bootloader to run.No information on its site.
thanks and regards
picstudent
