Go to www.arm.com
in the documentation link u will find all the amba bus protocol and amba bus architecute ... he uses a non synthasisable soc design to explain the amba soc architecture . I have not come across any texts that deal with this ..
Earlier even i was searching for a book on AMBA architecture. Later I have found that there is no dedicated book as such. But a combination of following documents helped me do the job.
1. AMBA bus protocal specification you can find it from arm website.
2. ARM system on chip architecture from Addison wesley. (You can try searching this book in the forum you will get it)
I think you are not right . I cant diagest it , "Combination of three is Called AMBA AHB" I think combination of three is called AMBA 2.0 and if the Newer Version
AXI Comes in a picture with above then it will called AMBA 3.0.
