body effect and region of operation
myboyki
Newbie level 2
I am trying to find a q point. There is a body effect, but my vtn is 1 anyways. What region of operation should I assume. Saturation region or triode region?
analogLow
Member level 4
Earth
Assuming that your Vgs (gate-to-source voltage) is larger than Vtn, then the operation region only depends on Vds (assuming the basic square-law model). In that case, if Vds is greater than Vgs-Vtn, then you are in the saturation region, else the triode. Of course if you are using a newer digital process, the the rules change and so the region definitions.
Cheers,
analogLow
