Hello, I am having dilemma in measuring the bluetooth antenna performance. The problem I have is that there are unavoidable cables and flex nearby the monopole bluetooth antenna, typically the flex is < 1.5mm distance to the antenna while the cable is dangling around the antenna.
It has been a frustrating engineering work to tune the matching circuit while not getting the intended efficiency based on the good S11 that I achieved. I know this is due to the loading of the surroundings that just cause the reflection to be less as the line just sees it as a good 50ohm line.
I decided tune by to do a OTA RF power measurement. The more I did, I found the power too varies due to the dangling cables around the antenna. The cables location varies during assembly which I realized is causing my OTA power measurement to varies too.
Any useful ideas I should do in order to control my measurement and confirm the performance? Should I just remove the cable and flex and measure ? but I know the actual performance has to be in a complete set. There is little space to control the location of the flex and wire. What should I do to really quantify my measurement ? thanks....
