mtwieg
Advanced Member level 6
Recently for a contract I'm working on, I opted to use a themal pad for a thermal interface between some surface mount FETs and an aluminum heat spreader. I've had experience with silicon TIMs before, but for this I wanted to try something with better thermal performance so after looking for a while I found the PC94 material and bought some to use. Now that I've got it in my hands, it's a lot different from what I expected.
First, it has the feel of a gummi candy, or chewed bubble gum, only much thinner. As in it can be easily stretched and torn with little effort. It's very soft, but has a very "tacky" surface. In the product datasheet, it gives a curve of thermal impedance and compression vs pressure, which is the main piece of info I used to select it. But now that I can feel how soft this stuff is, that curve doesn't seem right, and lo and behold if I go on **broken link removed** I find **broken link removed** which is completely different (the datasheet linked on that page gives the first curve...). I've sent an inquiry about the discrepancy, no reply yet.
Anyways, my real question is how one should handle a soft, fragile thermal pad like this, including in a high volume manufacturing process? I imagine it would be pretty easy to cut with a simple punch. But for actually applying and assembling it, how would that be done? It's as limp as a wet noodle, so it takes me a bit of coaxing to get it to lie flat in the right position, I can't imaging how a machine could do it. Or are these kind of things always hand assembled anyways?
