flote21
Advanced Member level 1
- Joined
- Jan 22, 2014
- Messages
- 411
- Helped
- 1
- Reputation
- 2
- Reaction score
- 3
- Trophy points
- 1,298
- Activity points
- 5,595
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 reg [4*8-1:0] pixels; reg [4*8-1:0] save_pixels; reg [2:0] clk_cnt; reg [5*8-1:0] five_pixels; //...code to generate clk_cnt, save_pixels, and pixels // pixels need to be selected according to the following table // clocks // 0 1 2 3 - 0 // 0 - 1 // // 1 2 3 // 0 1 - 2 // // 2 3 // 0 1 2 - 3 // // 3 // 0 1 2 3 - 4 always @ (posedge clk) begin case (clk_cnt) 0 : five_pixels <= five_pixels; 1 : five_pixels <= {save_pixels[0 +:4*8], pixels[32-(1*8) +:1*8]}; 2 : five_pixels <= {save_pixels[0 +:3*8], pixels[32-(2*8) +:2*8]}; 3 : five_pixels <= {save_pixels[0 +:2*8], pixels[32-(3*8) +:3*8]}; 4 : five_pixels <= {save_pixels[0 +:1*8], pixels[32-(4*8) +:4*8]}; default : five_pixels <= {5*8{1'bx}}; endcase end
Do you even understand what you just asked?But the problem is that with that solution I can't ouput data every clock after the pipeline delay... I need one solution to ouput data every clock without "deadtimes" in the output...Any idea?
How are you supposed to output data on every clock when the binning involves adding 5 pixels together, when you only get 4 pixels every clock? Unless you were supposed to do some sort of running sum...(i.e. d1+d2+d3+d4+d5, d2+d3+d4+d5+d6, d3+d4+d5+d6+d7, etc) then you could compute it on every clock.
If your original algorithm is correct and you have to output bin data on every clock then you will have to output on a clock that is 4/5 the input clock frequency and use a FIFO to ensure you don't under/overflow the binned pixel output.
Regards
BTW, the implementation you proposed will use a lot more adders and will also be much slower as your implementation requires that the 3 additions in the first case are done in 1 clock cycle. If you implemented what I showed you and follow it by a pipelined adder you would use fewer adders and it could run at a much higher frequency.
Only if you are sticking to your requirement that you output binned pixels on each clock...the aggregate rate for output bins is 4/5 your input clock that sends you 4 pixels per clock.Why I need to use a FIFO to ensure you don't under/overflow the binned pixel output??
This doesn't make any sense based on your original request.I can binning the incomming pixels on the fly! but the problem of this solution is that I have output freq limitation. The pixels are incomming at 148.5 MHz and I need to output binning pixels at maximum 500Hz. But it does not work. The maximum frequency that I can set up is 350 Hz. And I think that my pipeline algorithm is limiting in any way the output frequency.
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 ------------------------ entity BINNING_4PIX is ------------------------ generic ( DATA_BITS : positive := 12 -- Data Bus Width ); port ( BIN_MODE : in std_logic_vector(2 downto 0); -- Binning Mode : "000" = 6x2, "001" = 3x1, "111" => no Binning (for Full Frame) -- Video Input Parallel Interface, sync'ed on VID_I_CLK VID_I_CLK : in std_logic; -- Video Input Clock VID_I_RST : in std_logic; -- Video Input Reset (Async Active High) VID_I_SOI : in std_logic; -- Video Input Start Of Image VID_I_SOL : in std_logic; -- Video Input Start Of Line VID_I_EOI : in std_logic; -- Video Input End Of Image VID_I_DARK : in std_logic; -- Video Input Dark Image '1', Bright '0' VID_I_DAV : in std_logic; -- Video Input Pixel Data Valid Flag VID_I_DATA : in std_logic_vector(4*DATA_BITS-1 downto 0); -- Video Input Pixel Data : 4 pixels -- Video Output Parallel Interface, sync'ed on VID_O_CLK VID_O_CLK : in std_logic; -- Video Output Clock VID_O_RST : in std_logic; -- Video Output Reset (Async Active High) VID_O_XSIZE : in std_logic_vector(11 downto 0); -- Video Output X Size VID_O_YSIZE : in std_logic_vector(11 downto 0); -- Video Output Y Size VID_O_SOI : out std_logic; -- Video Output Start of Image VID_O_SOL : out std_logic; -- Video Output Start of Line VID_O_EOI : out std_logic; -- Video Output End of Image VID_O_DARK : out std_logic; -- Video Output Dark Image '1', Bright '0' VID_O_DAV : out std_logic; -- Video Output Pixels Data Valid Flag VID_O_DATA : out std_logic_vector(63 downto 0); -- Video Output Pixels Data (4 pixels) VID_O_XCNT : out std_logic_vector(11 downto 0); -- Video Output Pixels Counter (0 for 1st pixel) VID_O_YCNT : out std_logic_vector(11 downto 0) -- Video Output Lines Counter (0 for 1st line ) ); ------------------------------------- end entity BINNING_4PIX; ------------------------------------- ------------------------------------- architecture RTL of BINNING_4PIX is ------------------------------------- ------- begin ------- -- --------------------------------- -- Horizontal Binning process -- --------------------------------- -- only done for Binning modes 5x1 and 10x BINNING_H_proc : process(VID_I_CLK, VID_I_RST) begin BIN_MODE_l <= (others => '0'); BIN_ADD1 <= (others => '0'); BIN_ADD2 <= (others => '0'); BIN_ADD3 <= (others => '0'); BIN_ADD4 <= (others => '0'); BIN_LINE <= '0'; BIN_DAV <= '0'; BIN_DATA <= (others => '0'); BIN_DAV2 <= '0'; BIN_DATA2 <= (others => '0'); BIN_SEL <= (others => '0'); BIN_SELr <= (others => '0'); VID_F_SOI <= '0'; VID_F_DARK <= '0'; VID_F_SOL <= '0'; elsif rising_edge(VID_I_CLK) then -- Latch Dropping Factors + Reset Counters VID_F_SOI <= '0'; if VID_I_SOI = '1' then BIN_MODE_l <= BIN_MODEs; -- Latching Binning Mode VID_F_SOI <= '1'; VID_F_DARK <= VID_I_DARK; -- Latch Dark Info BIN_LINE <= '1'; -- will be '0' for Even Lines, '1' for Odd lines end if; -- Valid Lines Management VID_F_SOL <= '0'; if VID_I_SOL = '1' then -- New line BIN_LINE <= not BIN_LINE; BIN_ADD1 <= (others => '0'); BIN_ADD2 <= (others => '0'); BIN_ADD3 <= (others => '0'); BIN_ADD4 <= (others => '0'); if BIN_MODE_l = "010" then -- Binning 5x1 BIN_SELr <= (others => '0'); BIN_SEL <= (others => '0'); VID_F_SOL <= '1'; -- Output every line elsif BIN_MODE_l = "011" then -- Binning 10x2 BIN_SEL <= (others =>'0'); VID_F_SOL <= not BIN_LINE; -- Output 1 line out of 2 end if; end if; -- Pipeline Stage 1 -- Valid Pixels Management : -- Receiving 4 pixels on every clock cycle VID_I_DAVr <= '0'; if VID_I_DAV = '1' then -- New "4pixels" VID_I_DAVr <= '1'; -- for the pipeline BIN_SEL <= BIN_SEL + 1; -- Binning 5x1 if BIN_MODE_l = "010" then if BIN_SELr = 3 then BIN_SEL <= (others => '0'); end if; if BIN_SEL = 0 then BIN_ADD1 <= resize(unsigned(VID_I_DATA(11 downto 00)), BIN_ADD1'length) + unsigned(VID_I_DATA(23 downto 12)); BIN_ADD2 <= resize(unsigned(VID_I_DATA(35 downto 24)), BIN_ADD2'length) + unsigned(VID_I_DATA(47 downto 36)); elsif BIN_SEL = 1 then BIN_ADD3 <= resize(unsigned(VID_I_DATA(23 downto 12)), BIN_ADD3'length) + unsigned(VID_I_DATA(35 downto 24)); BIN_ADD4 <= resize(unsigned(VID_I_DATA(47 downto 36)), BIN_ADD4'length); elsif BIN_SEL = 2 then BIN_ADD1 <= resize(unsigned(VID_I_DATA(35 downto 24)), BIN_ADD1'length) + unsigned(VID_I_DATA(47 downto 36)); elsif BIN_SEL = 3 then BIN_ADD2 <= resize(unsigned(VID_I_DATA(47 downto 36)), BIN_ADD2'length); end if; -- Binning 10x2 elsif BIN_MODE_l = "011" then if BIN_SELr = 3 then BIN_SEL <= (others => '0'); end if; if BIN_SEL = 0 then BIN_ADD1 <= resize(unsigned(VID_I_DATA(11 downto 00)), BIN_ADD1'length) + unsigned(VID_I_DATA(23 downto 12)); BIN_ADD2 <= resize(unsigned(VID_I_DATA(35 downto 24)), BIN_ADD2'length) + unsigned(VID_I_DATA(47 downto 36)); elsif BIN_SEL = 1 then BIN_ADD3 <= resize(unsigned(VID_I_DATA(11 downto 00)), BIN_ADD3'length) + unsigned(VID_I_DATA(23 downto 12)); BIN_ADD4 <= resize(unsigned(VID_I_DATA(35 downto 24)), BIN_ADD4'length) + unsigned(VID_I_DATA(47 downto 36)); elsif BIN_SEL = 2 then BIN_ADD1 <= resize(unsigned(VID_I_DATA(35 downto 24)), BIN_ADD1'length) + unsigned(VID_I_DATA(47 downto 36)); elsif BIN_SEL = 3 then BIN_ADD3 <= resize(unsigned(VID_I_DATA(11 downto 00)), BIN_ADD3'length) + unsigned(VID_I_DATA(23 downto 12)); BIN_ADD4 <= resize(unsigned(VID_I_DATA(35 downto 24)), BIN_ADD4'length) + unsigned(VID_I_DATA(47 downto 36)); end if; end if; end if; -- Pipeline Stage 2 BIN_DAV <= '0'; BIN_DAV2 <= '0'; if VID_I_DAVr = '1' then if BIN_MODE_l = "010" then if BIN_SEL = 3 then BIN_SELr <= BIN_SEL; else BIN_SELr <= "000"; end if; if BIN_SEL = 1 then -- Valid Output BIN_DAV <= '1'; BIN_DATA <= std_logic_vector(resize(BIN_ADD1, BIN_DATA'length) + BIN_ADD2 + resize(unsigned(VID_I_DATA(11 downto 00)), BIN_DATA'length)); elsif BIN_SEL = 2 then -- Valid Output BIN_DAV <= '1'; BIN_DATA <= std_logic_vector(resize(BIN_ADD3, BIN_DATA'length) + BIN_ADD4 + resize(unsigned(VID_I_DATA(11 downto 00)), BIN_DATA'length) + resize(unsigned(VID_I_DATA(23 downto 12)), BIN_DATA'length)); elsif BIN_SEL = 3 then -- Valid Output BIN_DAV <= '1'; BIN_DATA <= std_logic_vector(resize(BIN_ADD1, BIN_DATA'length) + resize(unsigned(VID_I_DATA(11 downto 00)), BIN_DATA'length) + resize(unsigned(VID_I_DATA(23 downto 12)), BIN_DATA'length) + resize(unsigned(VID_I_DATA(35 downto 24)), BIN_DATA'length)); elsif BIN_SELr = 3 then -- Valid Output BIN_DAV <= '1'; BIN_DATA <= std_logic_vector(resize(BIN_ADD2, BIN_DATA'length) + resize(unsigned(VID_I_DATA(11 downto 00)), BIN_DATA'length) + resize(unsigned(VID_I_DATA(23 downto 12)), BIN_DATA'length) + resize(unsigned(VID_I_DATA(35 downto 24)), BIN_DATA'length) + resize(unsigned(VID_I_DATA(47 downto 36)), BIN_DATA'length)); end if; -- Binning 10x2 elsif BIN_MODE_l = "011" then if BIN_SEL = 3 then BIN_SELr <= BIN_SEL; else BIN_SELr <= "000"; end if; if BIN_SEL = 2 then BIN_DAV <= '1'; BIN_DATA <= std_logic_vector(resize(BIN_ADD1, BIN_DATA'length) + BIN_ADD2 + BIN_ADD3 + BIN_ADD4 + resize(unsigned(VID_I_DATA(11 downto 00)), BIN_DATA'length) + resize(unsigned(VID_I_DATA(23 downto 12)), BIN_DATA'length)); elsif BIN_SELr = 3 then BIN_DAV <= '1'; BIN_DATA <= std_logic_vector(resize(BIN_ADD1, BIN_DATA'length) + BIN_ADD3 + BIN_ADD4 + resize(unsigned(VID_I_DATA(11 downto 00)), BIN_DATA'length) + resize(unsigned(VID_I_DATA(23 downto 12)), BIN_DATA'length) + resize(unsigned(VID_I_DATA(35 downto 24)), BIN_DATA'length) + resize(unsigned(VID_I_DATA(47 downto 36)), BIN_DATA'length)); end if; end if; end if; end if; end process BINNING_H_proc; -- --------------------------------- -- Vertical Binning process -- --------------------------------- BINNING_V_proc : process(VID_I_CLK, VID_I_RST) begin if VID_I_RST = '1' then BIN_PACK_SEL <= '0'; BIN_PACK_WR <= '0'; BIN_PACK_DATA <= (others => '0'); VID_F_SEL <= '0'; VID_F_DAV <= '0'; VID_F_DATA <= (others => '0'); elsif rising_edge(VID_I_CLK) then BIN_PACK_WR <= '0'; -- Packing the 16bits pixels in 32bits if BIN_DAV = '1' then if BIN_MODE_l = "010" then BIN_PACK_DATA(47 downto 32) <= x"0000"; -- not used in this mode -- BIN_PACK_SEL <= not BIN_PACK_SEL; if BIN_PACK_SEL = '0' then BIN_PACK_DATA(15 downto 0) <= BIN_DATA; else BIN_PACK_WR <= '1'; BIN_PACK_DATA(31 downto 16) <= BIN_DATA; end if; elsif BIN_MODE_l = "011" then BIN_PACK_DATA(47 downto 32) <= x"0000"; -- not used in this mode -- BIN_PACK_SEL <= not BIN_PACK_SEL; if BIN_PACK_SEL = '0' then BIN_PACK_DATA(15 downto 0) <= BIN_DATA; else BIN_PACK_WR <= '1'; BIN_PACK_DATA(31 downto 16) <= BIN_DATA; end if; end if; end if; VID_F_DAV <= '0'; if BIN_MODE_l = "010" then if BIN_PACK_WR = '1' then if VID_F_SEL = '0' then VID_F_SEL <= '1'; VID_F_DATA(31 downto 00) <= BIN_PACK_DATA(31 downto 0); else VID_F_SEL <= '0'; VID_F_DAV <= '1'; VID_F_DATA(63 downto 32) <= BIN_PACK_DATA(31 downto 0); end if; end if; -- Binning 10x2 : For Odd lines, read from Fifo and compute the Final results elsif BIN_MODE_l = "011" then if BIN_FIFO_RD = '1' then -- New Data if VID_F_SEL = '0' then VID_F_SEL <= '1'; VID_F_DATA(15 downto 00) <= std_logic_vector(resize(unsigned(BIN_FIFO_OUT(15 downto 00)), 16) + unsigned(BIN_PACK_DATA(15 downto 00))); VID_F_DATA(31 downto 16) <= std_logic_vector(resize(unsigned(BIN_FIFO_OUT(31 downto 16)), 16) + unsigned(BIN_PACK_DATA(31 downto 16))); else VID_F_SEL <= '0'; VID_F_DAV <= '1'; VID_F_DATA(47 downto 32) <= std_logic_vector(resize(unsigned(BIN_FIFO_OUT(15 downto 00)), 16) + unsigned(BIN_PACK_DATA(15 downto 00))); VID_F_DATA(63 downto 48) <= std_logic_vector(resize(unsigned(BIN_FIFO_OUT(31 downto 16)), 16) + unsigned(BIN_PACK_DATA(31 downto 16))); end if; end if; end if; -- Initialize things on Start of Line if VID_I_SOL = '1' then BIN_PACK_SEL <= '0'; end if; end if; end process BINNING_V_proc; -- FIFO to store the Binning Results of Even Lines -- Will be read when Odd lines arrive, to compute the final results -- of each "couple of lines" (10x2 binning) -- Show Ahead Mode, Output Registered -- Storing the Binning H results in FIFO for Even lines : only for Binning 10x2 BIN_FIFO_WR <= BIN_PACK_WR and not BIN_LINE when BIN_MODE_l = "011" else '0'; BIN_FIFO_IN <= BIN_PACK_DATA; -- The FIFO (synchronous) i_BIN_FIFO : SCFIFO generic map ( ADD_RAM_OUTPUT_REGISTER => "ON", INTENDED_DEVICE_FAMILY => "Cyclone IV", LPM_NUMWORDS => 2**BIN_FIFO_DEPTH, LPM_SHOWAHEAD => "ON", LPM_TYPE => "SCFIFO", LPM_WIDTH => BIN_FIFO_WIDTH, LPM_WIDTHU => BIN_FIFO_DEPTH, OVERFLOW_CHECKING => "ON", UNDERFLOW_CHECKING => "ON", USE_EAB => "ON" ) port map ( ACLR => VID_I_RST , CLOCK => VID_I_CLK , SCLR => '0' , WRREQ => BIN_FIFO_WR , DATA => BIN_FIFO_IN , FULL => BIN_FIFO_FUL, USEDW => open , EMPTY => BIN_FIFO_EMP, RDREQ => BIN_FIFO_RD , Q => BIN_FIFO_OUT ); -- Extracting FIFO (Binning 10x2 only) -- when Odd Lines received and new data computed (Binning 10x2) BIN_FIFO_RD <= not BIN_FIFO_EMP and BIN_PACK_WR and BIN_LINE when BIN_MODE_l = "011" else '0'; -- when Odd Lines received and new data computed (Binning 6x2 and 10x2) -- ------------------------------------- -- Clock Domain Crossing to VID_O_CLK -- ------------------------------------- -- FIFO to store the 64bits Binning Results -- and to perform the Clock Domain Crossing to VID_O_CLK -- Show Ahead Mode, Output Registered -- Writing in FIFO FIFO_WR <= VID_F_SOI or VID_F_SOL or VID_F_DAV; FIFO_IN <= VID_F_SOI & VID_F_SOL & VID_F_DAV & VID_F_DATA & VID_F_DARK; -- Clock Domain Crossing FIFO -- Show Ahead Mode, Output Registered -- Data Width 32 bits, Fifo Depth = 2**FIFO_DEPTH i_O_FIFO : DCFIFO generic map ( CLOCKS_ARE_SYNCHRONIZED => "FALSE", INTENDED_DEVICE_FAMILY => "Cyclone V", LPM_NUMWORDS => 2**FIFO_DEPTH, LPM_SHOWAHEAD => "ON", LPM_TYPE => "dcfifo", LPM_WIDTH => FIFO_WIDTH, LPM_WIDTHU => FIFO_DEPTH, OVERFLOW_CHECKING => "ON", UNDERFLOW_CHECKING => "ON", USE_EAB => "ON", WRSYNC_DELAYPIPE => 3, RDSYNC_DELAYPIPE => 3, READ_ACLR_SYNCH => "ON", WRITE_ACLR_SYNCH => "ON" ) port map ( ACLR => VID_I_RST, WRCLK => VID_I_CLK, WRREQ => FIFO_WR , DATA => FIFO_IN , WRUSEDW => open , WRFULL => FIFO_FUL , RDCLK => VID_O_CLK, RDEMPTY => FIFO_EMP , RDREQ => FIFO_RD , Q => FIFO_OUT , RDUSEDW => open ); -- Checking FIFO Flags process(VID_I_CLK) begin if rising_edge(VID_I_CLK) then assert not ( FIFO_WR = '1' and FIFO_FUL = '1' ) report "[BINNING_4PIX] WRITE while i_O_FIFO Full !!!" severity failure; end if; end process; process(VID_O_CLK) begin if rising_edge(VID_O_CLK) then assert not ( FIFO_RD = '1' and FIFO_EMP = '1' ) report "[BINNING_4PIX] READ while i_O_FIFO Empty !!!" severity failure; end if; end process; -- Reading the FIFO FIFO_RD <= not FIFO_EMP; -- Video Outputs VID_O_SOIi <= FIFO_RD and FIFO_OUT(67) when rising_edge(VID_O_CLK); VID_O_SOLi <= FIFO_RD and FIFO_OUT(66) when rising_edge(VID_O_CLK); VID_O_DAVi <= FIFO_RD and FIFO_OUT(65) when rising_edge(VID_O_CLK); VID_O_DATA <= FIFO_OUT(64 downto 1) when rising_edge(VID_O_CLK); -- ----------------------------------------------------- -- Outputting Data on VID_O_CLK clock domain -- ----------------------------------------------------- OUT_proc : process(VID_O_CLK, VID_O_RST) begin if VID_O_RST = '1' then VID_O_DARKi <= '0'; VID_O_EOIi <= '0'; VID_O_XCNTi <= (others => '0'); VID_O_YCNTi <= (others => '0'); elsif rising_edge(VID_O_CLK) then -- Dark/Bright Info if FIFO_RD = '1' and FIFO_OUT(67) = '1' then -- SOI VID_O_DARKi <= FIFO_OUT(0); end if; -- Output Pixel Counter if VID_O_DAVi = '1' then VID_O_XCNTi <= VID_O_XCNTi + 4; -- 2 pixels per 32bits end if; -- Output Line Counter if VID_O_SOIi = '1' then VID_O_YCNTi <= (others => '1'); elsif VID_O_SOLi = '1' then VID_O_XCNTi <= (others => '0'); VID_O_YCNTi <= VID_O_YCNTi + 1; end if; -- End of Image VID_O_EOIi <= '0'; if VID_O_DAVi = '1' and VID_O_XCNTi = unsigned(VID_O_XSIZE)-4 and VID_O_YCNTi = unsigned(VID_O_YSIZE)-1 then VID_O_EOIi <= '1'; end if; end if; end process OUT_proc; VID_O_SOI <= VID_O_SOIi ; VID_O_SOL <= VID_O_SOLi ; VID_O_EOI <= VID_O_EOIi ; VID_O_DARK <= VID_O_DARKi; VID_O_DAV <= VID_O_DAVi ; VID_O_XCNT <= std_logic_vector(VID_O_XCNTi); VID_O_YCNT <= std_logic_vector(VID_O_YCNTi);
I think you need to supply the testbench that you are using to test this entity/architecture. It's hard to determine what your input protocol would look like.
Like I said before your implementation choice uses a lot of adders, which would reduce to a single 5 pixel adder tree, if you performed the translation of 4 pixels to 5 pixels as I originally suggested.
It shouldn't be hard to translate what I posted to VHDL as there isn't anything complicated in the case statement. The case statement just translates the table above it.
The pixels are pipelined delayed so you have access to both the most recent pixel and the previous set of pixels. That gives you access to all 5 pixels you need for each bin.
Do your calculations include the Ethernet framing overhead? It doesn't look like it as you aren't adding amything else to the raw pixel data.
variable temp : unsigned(w+8 downto 0);
temp := d_in * 206;
d_out <= temp(w+8 downto 8);
Okay, I see the 700 Mbps is the maximum Ethernet payload rate, that wasn't clearly stated. 700Mbps is kind of low for Gigabit Ethernet, you must have rather short Ethernet packets.Yes In the maximum ETH frame rate (700 Mbps) is already included.
entity ETH_TX_CTRL is
port (
FIFO_WR_FUL_ERR : out std_logic; -- Fifo WR Full Error
FIFO_RD_FUL_ERR : out std_logic; -- Fifo RD Full Error
-- Clock and Reset
CLK : in std_logic; -- Module Clock
RST : in std_logic; -- Module Reset (Asynch Active high)
RUN : in std_logic; -- Run
-- Video Stream
VIDEO_XSIZE : in std_logic_vector(11 downto 0); -- Video X Size
VIDEO_YSIZE : in std_logic_vector(11 downto 0); -- Video Y Size
VIDEO_SOI : in std_logic; -- Video Start of Image
VIDEO_DAV : in std_logic; -- Video Data Valid
VIDEO_DATA : in std_logic_vector(63 downto 0); -- Video Data
VIDEO_EOI : in std_logic; -- Video End of Image
-- uC Data Interface, to insert inside TX Video Frames
UC_TX_DAV : in std_logic; -- uC New Data to Send
UC_TX_DATA : in std_logic_vector(23 downto 0); -- uC New Data
-- Encryption
ENCRYPT_IN : in std_logic_vector(31 downto 0); -- Encrypt Value to send in the Ethernet Frames
-- GEDEK Interface
ETH_TXREADY : in std_logic; -- Ethernet Tx Ready ('0' = not ready !)
ETH_TXSOP : out std_logic; -- Ethernet Tx Start of Packet
ETH_TXDAV : out std_logic; -- Ethernet Tx Data Valid
ETH_TXDATA : out std_logic_vector(31 downto 0); -- Ethernet Tx Data
ETH_TXEOP : out std_logic -- Ethernet Tx End of Packet
end entity ETH_TX_CTRL;
architecture RTL of ETH_TX_CTRL is
-- Altera Single Clock FIFO
component SCFIFO is
generic (
ADD_RAM_OUTPUT_REGISTER : string;
INTENDED_DEVICE_FAMILY : string;
LPM_NUMWORDS : natural;
LPM_SHOWAHEAD : string;
LPM_TYPE : string;
LPM_WIDTH : natural;
LPM_WIDTHU : natural;
OVERFLOW_CHECKING : string;
UNDERFLOW_CHECKING : string;
USE_EAB : string
port (
ACLR : in std_logic ;
CLOCK : in std_logic ;
SCLR : in std_logic ;
WRREQ : in std_logic ;
DATA : in std_logic_vector(LPM_WIDTH -1 downto 0);
FULL : out std_logic ;
USEDW : out std_logic_vector(LPM_WIDTHU-1 downto 0);
EMPTY : out std_logic ;
RDREQ : in std_logic ;
Q : out std_logic_vector(LPM_WIDTH -1 downto 0)
end component SCFIFO;
constant RESOLUTION_X : std_logic_vector(15 downto 0) := std_logic_vector(to_unsigned(48, 16));
constant RESOLUTION_Y : std_logic_vector(15 downto 0) := std_logic_vector(to_unsigned(96, 16));
-- FIFO to store Video Data
constant FIFO_DEPTH : positive := 10;
constant FIFO_WSIZE : positive := 64;
signal FIFO_CLR : std_logic;
signal FIFO_WR : std_logic;
signal FIFO_IN : std_logic_vector(FIFO_WSIZE-1 downto 0);
signal FIFO_FUL : std_logic;
signal FIFO_NB : std_logic_vector(FIFO_DEPTH-1 downto 0);
signal FIFO_EMP : std_logic;
signal FIFO_RD : std_logic;
signal FIFO_OUT : std_logic_vector(FIFO_WSIZE-1 downto 0);
signal FIFO_RDSEL : std_logic;
-- FIFO to store uC Data
constant UC_FIFO_DEPTH : positive := 8;
constant UC_FIFO_WSIZE : positive := 32;
signal UC_FIFO_CLR : std_logic;
signal UC_FIFO_WR : std_logic;
signal UC_FIFO_IN : std_logic_vector(UC_FIFO_WSIZE-1 downto 0);
signal UC_FIFO_FUL : std_logic;
signal UC_FIFO_NB : std_logic_vector(UC_FIFO_DEPTH-1 downto 0);
signal UC_FIFO_EMP : std_logic;
signal UC_FIFO_RD : std_logic;
signal UC_FIFO_OUT : std_logic_vector(UC_FIFO_WSIZE-1 downto 0);
signal UC_PACK_CNT : unsigned(15 downto 0);
signal VIDEO_RUN : std_logic;
signal VIDEO_SOIm : std_logic;
signal VIDEO_EOIm : std_logic;
signal FRAME_CNT : unsigned(31 downto 0);
constant ETH_TXSIZE : positive := 361; -- 3 UDP Headers + 358 x 32bits words Data : max optimal value
type ETH_TXFSM_t is ( s_IDLE, s_SEND_INFO_1, s_SEND_INFO_2, s_SEND_INFO_3, s_SEND_DATA, s_SEND_EOP );
signal ETH_TXFSM : ETH_TXFSM_t;
signal ETH_TXEND : std_logic;
signal ETH_TXCNT : integer range 0 to ETH_TXSIZE;
begin
-- VIDEO DATA FIFO
FIFO_CLR <= VIDEO_SOI or not RUN;
FIFO_WR <= VIDEO_DAV and VIDEO_RUN;
FIFO_IN <= VIDEO_DATA;
-- FIFO to store incoming data to send to GEDEK
-- Perform 64bits to 32bits conversion !
i_VIDEO_FIFO : SCFIFO
generic map (
LPM_WIDTH => FIFO_WSIZE,
USE_EAB => "ON"
port map (
ACLR => RST ,
CLOCK => CLK ,
SCLR => FIFO_CLR,
WRREQ => FIFO_WR ,
DATA => FIFO_IN ,
FULL => FIFO_FUL,
USEDW => FIFO_NB ,
EMPTY => FIFO_EMP,
RDREQ => FIFO_RD ,
Q => FIFO_OUT
FIFO_RD <= ETH_TXREADY and not FIFO_EMP and FIFO_RDSEL when ETH_TXFSM = s_SEND_DATA else '0';
-- FIFO Full Error Detection
process(CLK, RST)
begin
if RST = '1' then
FIFO_WR_FUL_ERR <= '0';
elsif rising_edge(CLK) then
if FIFO_FUL = '1' and FIFO_WR = '1' then
FIFO_WR_FUL_ERR <= '1';
end if;
end if;
end process;
process(CLK, RST)
begin
if RST = '1' then
FIFO_RD_FUL_ERR <= '0';
if FIFO_EMP = '1' and FIFO_RD = '1' then
FIFO_RD_FUL_ERR <= '1';
end if;
end if;
end process;
-- FIFO assertions
process
begin
wait until rising_edge(CLK);
assert not (FIFO_EMP = '1' and FIFO_RD = '1')
report "[ETH_TX_CTRL] Try to read while FIFO is empty !" severity failure;
assert not (FIFO_FUL = '1' and FIFO_WR = '1')
report "[ETH_TX_CTRL] Write in FIFO Full !" severity failure;
end process;
-- uC DATA FIFO
UC_FIFO_CLR <= not RUN;
UC_FIFO_WR <= UC_TX_DAV and VIDEO_RUN;
UC_FIFO_IN <= x"00" & UC_TX_DATA;
-- FIFO to store incoming data from GEDEK
-- FIFO 1024x32bits, Show Ahead Mode, Output registered
i_UC_FIFO : SCFIFO
generic map (
LPM_NUMWORDS => 2**UC_FIFO_DEPTH,
LPM_WIDTH => UC_FIFO_WSIZE,
LPM_WIDTHU => UC_FIFO_DEPTH,
USE_EAB => "ON"
port map (
ACLR => RST ,
CLOCK => CLK ,
SCLR => UC_FIFO_CLR,
WRREQ => UC_FIFO_WR ,
DATA => UC_FIFO_IN ,
FULL => UC_FIFO_FUL,
USEDW => UC_FIFO_NB ,
EMPTY => UC_FIFO_EMP,
RDREQ => UC_FIFO_RD ,
Q => UC_FIFO_OUT
-- uC FIFO assertions
process
begin
assert not (UC_FIFO_EMP = '1' and UC_FIFO_RD = '1')
report "[ETH_TX_CTRL] Try to read while UC_FIFO is empty !" severity failure;
assert not (UC_FIFO_FUL = '1'and UC_FIFO_WR = '1')
report "[ETH_TX_CTRL] Write in UC_FIFO Full !" severity failure;
end process;
-- TX FRAME MANAGEMENT
TX_proc : process(RST,CLK)
begin
if RST='1' then
ETH_TXEND <= '0';
ETH_TXSOP <= '0';
ETH_TXEOP <= '0';
ETH_TXDAV <= '0';
ETH_TXDATA <= (others => '0');
ETH_TXCNT <= 0 ;
ETH_TXFSM <= s_IDLE;
FRAME_CNT <= (others => '0');
VIDEO_RUN <= '0';
VIDEO_SOIm <= '0';
VIDEO_EOIm <= '0';
UC_PACK_CNT <= (others=>'0');
UC_FIFO_RD <= '0';
FIFO_RDSEL <= '0';
UC_FIFO_RD <= '0';
-- Latch Run Signals at Start of Frame
if RUN = '0' then
VIDEO_RUN <= '0';
elsif VIDEO_SOI = '1' then
VIDEO_RUN <= RUN;
end if;
-- Memorize Start / End of Image Flags
VIDEO_SOIm <= (VIDEO_SOIm or VIDEO_SOI) and RUN;
VIDEO_EOIm <= (VIDEO_EOIm or VIDEO_EOI) and VIDEO_RUN;
case ETH_TXFSM is
-- Idle State : waiting for :
-- * Enough data to send in the Fifo ?
-- * End of Image flag from Video Interface
when s_IDLE =>
ETH_TXSOP <= '0';
ETH_TXEOP <= '0';
ETH_TXDAV <= '0';
ETH_TXEND <= '0';
-- Enough Words in FIFO
if unsigned(FIFO_NB)*2 >= ETH_TXSIZE-3 then
ETH_TXCNT <= ETH_TXSIZE-3; -- Load Number of Data to send
ETH_TXFSM <= s_SEND_INFO_1; -- Go Send UDP Header
-- End of Image !
elsif VIDEO_EOIm = '1' then
ETH_TXEND <= '1'; -- will be used to clear the EOIm
ETH_TXCNT <= to_integer(unsigned(FIFO_NB))*2; -- Load Number of Data to send
end if;
-- UDP Header Word 1 :
-- * if First Frame for the Image, send the Resolution
-- * else send the Packets Counter on 16 MSBs
when s_SEND_INFO_1 =>
-- Send the SOP of this frame
ETH_TXSOP <= '1';
ETH_TXDAV <= '1';
if VIDEO_SOIm = '1' then -- New Image
ETH_TXDATA <= x"0" & VIDEO_YSIZE & x"0" & VIDEO_XSIZE;
UC_PACK_CNT <= (others => '0'); -- Reset Packets counter
else
ETH_TXDATA <= x"0000" & std_logic_vector(UC_PACK_CNT);
UC_PACK_CNT <= UC_PACK_CNT + 1; -- Increment for next time
end if;
ETH_TXFSM <= s_SEND_INFO_2;
-- UDP Header Word 2 : Video Frame Counter
when s_SEND_INFO_2 =>
if ETH_TXREADY = '1' then -- SOP accepted
ETH_TXSOP <= '0'; -- release the SOP
ETH_TXDAV <= '1'; -- send 2nd data
ETH_TXDATA <= std_logic_vector(FRAME_CNT);
ETH_TXFSM <= s_SEND_INFO_3;
end if;
-- UDP Header Word 3 :
-- * if First Frame for the Image, send the Encryption Word
-- * else send the uC Word (if anything to send)
-- * else 0's
when s_SEND_INFO_3 =>
if ETH_TXREADY = '1' then -- 2nd data accepted
ETH_TXDAV <= '1';
ETH_TXDATA <= ENCRYPT_IN; -- Encryption Word
else
-- Something to Send on the Dedicated uC Word in UDP Header ?
if UC_FIFO_EMP = '0' then -- Yes (uC has sent something to the FPGA)
UC_FIFO_RD <= '1'; -- Read the word now so that it will be available after
ETH_TXDATA <= UC_FIFO_OUT; -- uC Word
else
ETH_TXDATA <= (others => '0'); -- All Zeros
end if;
end if;
VIDEO_SOIm <= '0'; -- Clear the Start of Image flag now
FIFO_RDSEL <= '0';
ETH_TXFSM <= s_SEND_DATA;
end if;
-- Sending Data
when s_SEND_DATA =>
ETH_TXDAV <= '1';
if FIFO_RD = '1' then
ETH_TXDATA <= FIFO_OUT(63 downto 32);
elsif FIFO_EMP = '0' and FIFO_RDSEL = '0' then
ETH_TXDATA <= FIFO_OUT(31 downto 00);
end if;
if ETH_TXREADY = '1' then -- Data Acknowledge by GEDEK
FIFO_RDSEL <= not FIFO_RDSEL;
if ETH_TXCNT = 1 then
ETH_TXEOP <= '1';
ETH_TXFSM <= s_SEND_EOP;
-- Clear the EOIm only if it was really the last frame to send
if VIDEO_EOIm = '1' and ETH_TXEND = '1' then
FRAME_CNT <= FRAME_CNT + 1;
VIDEO_EOIm <= '0'; -- Clear the End of Image flag now
end if;
end if;
ETH_TXCNT <= ETH_TXCNT - 1;
end if;
-- Sending EOP
when s_SEND_EOP =>
ETH_TXDAV <= '0'; -- release the DAV
ETH_TXEOP <= '0'; -- release the EOP
end if;
end case;
end if;
end process TX_proc;
end architecture RTL;
One thing you should check in a simulation or in the signaltap is monitor the UC_FIFO_NB used count and see how it behaves. I suspect you will discover the count fluctuates in such a way that the FIFO is going empty due to bursting when packets are sent. UDP has a pretty low overhead so you should easily be able to send 700Mbps.
I suggest running for many packets to see the overall trend of the FIFO level as it runs. You may not have run enough packets to see what is happening. Setting the UC_FIFO_NB count to an unsigned analog display in Modelsim, will give you a nice view of what is going on.
I have already found problem!!! I was losing pixel and frames due to the PEAK the Bandwidth of the Ethernet side. This is the equation to handle this stuff:
For example, given a RealFrame = 1920 pixels x 219 lines. Aftter doing an Horizontal binning of 5 (Adding 5 pixels together) => BinnedFrame = 1920/5 x 219 = 384x219.
If I want to run the system at frame_rate = 500Hz => LineTime=219/500=9.13uS. But during a complete line I have to send 384x16bits=6144bits. So we have to send in average 6144bits in 9.13 uS => BW_ETH=672.94Mbps. Very close to the 700Mbps which is the limitation of my ETH interface....
This is a limitation of the system so I can't do any more here.
Thanks anyway for your interest and help. Thanks a lot dude!!!
